Posted: Friday Apr 2nd, 2010 03:12 am |
The screenshots show an example of the power of the UCM/KNX when used with a KNX Touchscreen, courtesy of Domotiks, our distributor in Spain
The Comfort keypad can be simulated on the touchscreen allowing the user to enter their Comfort user code to arm and disarm the security system just like a real keypad!
The user code is the same as on Comfort. if the user changes the code, then the same code must be used on the KNX touchscreen. In other words KNX does not keep the user code, thus leading to greater security. Note: use 1 byte Datapoint Type 5.010 type in ETS for the keypad keys
The security mode buttons Away, Night, day, Vacation can be used to arm the securty system, and the buttons also show the actual security mode, for example if Comfort was armed by another keypad to Night Mode, the Night mode button would show as active.
Comfort's Date and Time can also be shown on the touchscreen
Attachment: Pantallazo - Pantalla Principal - Imitación teclado.png (Downloaded 354 times) Last edited on Tuesday Jan 11th, 2022 10:45 am by slychiu
Posted: Friday Apr 2nd, 2010 03:15 am |
Comfort's Trouble conditions like AC Failure, Low Battery, RS485 Communications failure, Zone Trouble, Phone Line cut can be shown. The UCM/KNX allows Comfort's security conditions to be visible on the KNX Bus
Attachment: Pantallazo - Estado del Sistema - Todo rojo.png (Downloaded 323 times)
Posted: Friday Apr 2nd, 2010 03:18 am |
Posted: Friday Apr 2nd, 2010 03:20 am |
Posted: Friday Apr 2nd, 2010 03:23 am |
Posted: Friday Apr 16th, 2010 09:47 am |
TheMax74
Posts: | 247 |
The touchpanel seems to be the Gira Infoterminal Touch.
Posted: Friday Apr 16th, 2010 12:08 pm |
Posts: | 1200 |
I believe it is but any KNX Touchscreen can be used in the same way
Comfort allows all alarm conditions to be viewed on the KNX bus. This is quite a unque capability
Posted: Thursday Sep 30th, 2010 07:41 am |
joshua963
Restricted
Posts: | 5 |
currently working on a project similar to this whereby a KNX touchscreen is integrated with comfort. Any programming reference/samples is available to refer to ??
thank you.Last edited on Thursday Sep 30th, 2010 07:42 am by joshua963
Posted: Friday Oct 8th, 2010 01:31 am |
A typical cclx file is attached. You need Comfigurator 3 to open this. Look at the Modules Tab > UCM > UCM02 and see the KNX Properties, KNX to Comfort and Comfort to KNX
An example is available using the Jung Touchscreen
Let us know if you have any questions or problems
Please post on a new topic
Attachment: knxtest.zip (Downloaded 47 times)
Posted: Monday Feb 3rd, 2014 10:51 am |
Does anyone have other screenshot examples of touchsreen or visualisation with the Comfort alarm? we could show it on the forum
Posted: Monday Feb 3rd, 2014 11:10 am |
TheMax74
Posts: | 247 |
Hello,here is my touch.In the middle, Comfort keyboard.On the upper righr, buttons to open doors and gates through ComfortOn the lower right, bypass control of Microwaves.
Attachment: Comfort.png (Downloaded 111 times)
Posted: Monday Feb 3rd, 2014 12:05 pm |
Thanks, that is a nice one
Posted: Monday Feb 3rd, 2014 02:02 pm |
Vangelis
Posts: | 138 |
Hey Max74 - Is that a custom app or off the shelf? Looks very neat...
Vangelis
Posted: Monday Feb 3rd, 2014 02:17 pm |
TheMax74
Posts: | 247 |
It's a JQuery interface called SmartVISU, with customization.
The system is based on IIS + custom c# interface acting as bridge, between SmartVISU and KNX, via a device called EIBPC (this is a KNX controller).
You can find more info about Smartvisu here.
http://smartvisu.de/
Throug this interface, i control Comfort, but also KNX light and devices and Spotify too.
If you intend to control only Comfort, your "bridging chain" will be much simpler.
