Posted: Sunday Jul 5th, 2009 09:07 am |
Posts: | 1200 |
The UCM/KNX has been replaced by UCM/KNX2, which is a more advanced KNX interface, see http://www.comfortforums.com/view_topic.php?id=4470&forum_id=12&jump_to=20570#p20570
Cytech is pleased to announce that we have developed a 2nd generation KNX interface, which we call UCM/KNX to distinguish from the current UCM/EIB. The UCM/KNX will be similar to the UCM/EIB but will have an Nonvolatile EEPROM in U2 to hold the configuration data.
This will be much more closely integrated with KNX than before.
The UCM/KNX interface allows the alarm system to be fully visible on KNX; the status of alarms and which doors, windows or motion sensors are activated, and whether the security system is set or unset are mapped to assigned group addresses. It allows KNX switches and input devices to send commands to Comfort to bypass zones, or to control outputs or other devices.
A KNX touchscreen can be used to set and unset the security system by entering the user code, just like a physical keypad.
Instead of mapping group addresses to Counters by shunts, there will be a software configuration which is part of Comfigurator 3 to map Group addresses to Comfort. This makes it easy to program Comfort to interface with KNX, without requiring a lot of knowledge of Comfort. Comfigurator 3.18 and above is required to support KNX software configuration.
The screen below shows UCM/KNX Properties page.
The UCM/KNX can be assigned any valid Physical address, hence several UCM/KNX can be used in the same system to connect to a single KNX system, or with several independent KNX systems
The screenshot below shows KNX to Comfort Page which maps KNX Group addresses to Comfort
In the KNX to Comfort page, you can - Map KNX 1-bit, 4-bit, 1 byte and 2 byte group addresses to Comfort counters or sensors
- Learn Mode will show the KNX group addresses of any KNX telegram received, to be mapped to Comfort. TEST ON and OFF buttons directly send telegrams to learnt group addresses
- You can assign 1-bit group addresses for commands to Arm to Away, Night, Day or vacation modes which are updated when the system arms or disarms - two way
- You can assign group addresses to Bypass Comfort zones which are updated when the zone is bypassed and unbypassed - two way
- You can assign a 1 byte group address to simulate keypad keys so a touchscreen can be used to disarm Comfort using user codes
- You can map group addresses to KNX Date and Time objects so Comfort and KNX time and date are synchronised - two way
The screenshot below shows the Comfort to KNX page where Comfort zones, alarms, and other events are mapped to KNX group addresses- Assign group addresses to Zone states and RIO Input states
- Assign 1-bit group addresses to Armed, Line Cut, AC Fail, Low battery, Tamper, Doorbell, Entry Alert conditions so that KNX can be automatically updated when Comfort changes its state
Monitor Mode allows received KNX telegrams to be displayed
The new UCM/KNX allows KNX integrators to interface with Comfort without having to program Responses, ie they dont need to know very much about Comfort. It is a very powerful tool for Comfort to KNX Integration
See UCM/KNX on the Cytech website at http://www.cytech.biz/knx_interface.html
The UCM/KNX Manual can be downloaded from http://www.cytech.biz/ucmknx_manual.htm
This should make Comfort an even more powerful proposition for KNX partners
Posted: Thursday Jul 9th, 2009 03:41 pm |
TheMax74
Posts: | 247 |
Good news. Thank you.
Posted: Wednesday Jul 22nd, 2009 09:01 am |
Posts: | 5499 |
The version of Comfigurator, 3.1.8 which supports the UCM/KNX is available,
Posted: Wednesday Jul 22nd, 2009 09:41 am |
TheMax74
Posts: | 247 |
Thanks for the infos. Already downloaded 3.0.8 and new KNX firmware.
I'm waiting for delivery of the UCM from cytechdirect.
Posted: Thursday Jul 23rd, 2009 08:28 am |
TheMax74
Posts: | 247 |
UCM/EIB arrived.
It has the U2 socket EEPROM on board, below the "reset" pushbutton, so i think is the new version and i don't need to upgrade any hardware.
As i can read from the ucmknx draft manual, my Ultra II firmware is ok (5.164), but my UCM05 isn't (5.156).
If i don't perform the "scan for ucm", is it mandatory to upgrade my UCM05 to a newest firmware ?
Thanks.
Posted: Thursday Jul 23rd, 2009 12:21 pm |
Posts: | 5499 |
You need UCM 5.178 to support the writing of comfiguration into the UCM/KNX from Comfigurator, as the older UCM does not have this function
If you dont have another UCM05 to upgrade it, we can do it for you for the cost of transport. Otherwise perhaps another user on the forum with a UCM which needs upgrading may be able help you out as both UCM05s can be upgraded if one of you sends the UCM to the other
Posted: Thursday Jul 23rd, 2009 12:47 pm |
TheMax74
Posts: | 247 |
I have another old UCM05. I will use this to upgrade my UCM/ETH.
Thanks.
Posted: Saturday Aug 1st, 2009 02:27 am |
Posted: Friday Aug 14th, 2009 09:24 am |
Posts: | 5499 |
The UCM/KNX is now officially released, please visit the download links highlighted below
Firmware version minimum = KNX 5.195
UCM05 Firmware minimum = UCM 5.192
Comfort Firmware minimum = ULT 5.172
Comfigurator 3.2.4 and above
Posted: Friday Aug 14th, 2009 09:27 am |
TheMax74
Posts: | 247 |
Well, great job.
No more problems with KNX 192 in the past two weeks.
Posted: Friday Aug 14th, 2009 09:39 am |
Posts: | 5499 |
Thats good. There were some minor bugs with 5.192 including the Read from Group Aggress that you reported. This has been fixed so you should upgrade to the new version
Posted: Saturday Aug 15th, 2009 04:00 am |
mrtae
Posts: | 41 |
Chiu,
Just FYI...
The link you provide below is point to UCM05 latest firmware.
Comfort Firmware minimum = 5.164 but ULT 5.169 is the latest
So the Comfort firmware ULT5.169 is an official release?
Posted: Sunday Aug 16th, 2009 03:55 am |
Posts: | 5499 |
The link is incorrect and will be corrected in the next few days. There is a problem with our servers currently
This topic shall be closed in order to prevent it from getting too long
Please post a new topic if you have any questions, comments or problems
