Comfort Automation/ Security System Forums > Products > UCM > UCM/ETH01 & UCM/ETH02 > Pb with UCM/ETH02 - failed to connect - erratic
 Moderated by: hendy
 Posted: Friday Jan 3rd, 2014 01:50 am
phil1155
I have last Eth2 firmware version.
Having Homeseer 2 and trying the pjccomfort plugin (which is not so far), I am checking my config with Tibbo DS manager. I can see the blue icon and my device set up at the right ip address, but mostly of the time, checking the settings give me an error message " no response from this device", while at the same time I can connect with Wizcomfort without a single problem.
Any idea?
Is anyone running HS and the pjc plugIn?
Thank you
Philippe
 Posted: Friday Jan 3rd, 2014 05:10 am
tech07
Who made the pjcomfort plug in? Can you get support from their techsupport?
 Posted: Friday Jan 3rd, 2014 04:09 pm
Pretty easy to find on internet:
http://www.pjcplugins.co.uk
 Posted: Monday Jan 6th, 2014 05:47 am
phil1155
Sure easy to find, I contacted him but no answer, hence my search for potential users.Thanks
 Posted: Monday Jan 6th, 2014 06:15 am
phil1155
But for now, I 'd like to solve my DS mabager problem first.
Tried with the blast version of DSmanager, but my Eth2 device is still not found. The firewall is off and my eth2 is on the same bridge where is my pc.
But again, wiz comfort still able to work with eth2!
 Posted: Monday Jan 6th, 2014 06:47 am
If wizcomfort is able to work with ETH02 then DS Manager must be able to find it
Try using DS Explorer from http://www.cytech.biz/device_explorer.html?category_id=98 and see if the ETH02 can be seen
Also try reinitialising the ETH02 using the SW101 button as described in the UCM Manual
SW101 (ETH02)
Pushbutton switch for reinitializing ETH02 to programming mode in case
firmware is corrupted.
  •  Power off UCM/ETH02.
  •  Press and hold SW101 switch.
  •  Power on UCM/ETH02.
  •  Release the SW101 switch after at least 7 seconds upon powered on.
  •  The Green LED on RJ45 connector will turn steady on and D101 red LED will
  • be flashing when the Ethernet cable is plugged in.
  •  Run Device Explorer software and refer to Device Explorer Software section
 Posted: Monday Jan 6th, 2014 07:37 am
phil1155
I tried again this sequence. No Change.
Explorer was ble to find the eth2, but this time the IP adress was wrong (1.0.0.1).
I downloaded the firmware 3.13 again , the eth2 rebooted and explorer shown eth2 with the right IP address. With DS manager, Eth2 is also appearing with the blue icon, but when I try to check the settings, a red arrow appears in front of the device, and I got an error message saying "no response from this device" , but wizcomfort is still communicating with comfort!
 Posted: Monday Jan 6th, 2014 11:00 am
Can you show the screenshot with the error message?
If wizcomfort and Comfigurator are working with the ETH02 then there should be no problem with it although we do not know  why you get the error.
I suggest using another PC with DS Manager and see if you see the same thing
 Posted: Monday Jan 6th, 2014 12:06 pm
phil1155
Just sent via email the screenshots.
 Posted: Monday Jan 6th, 2014 12:07 pm
phil1155
Email did not work, how to send them?
 Posted: Monday Jan 6th, 2014 12:15 pm
You can attach the screenshot to a post or send to support@cytech.biz
 Current time is 11:11 am
