Comfort Automation/ Security System Forums > Products > Relay/Automation Modules > Dimplex smart rad control via Pilot wire and Zoning
 Posted: Wednesday Nov 12th, 2014 12:20 am
MDKKEN
I have purchased Dimplex Smart fan convector radiators: these have a pilot wire when energised will set the radiator into ECO mode. The wire requires 100 milli amps at 230V.
What I would like to do - is when a PIR detects there is no one in the room is to put the radiator into ECO mode via energising the pilot wire.
What relays can I use for comfort to do this? How do I do this?
 Posted: Wednesday Nov 12th, 2014 05:59 am
You need a 230V relay to connect 230V to the pilot wire
The newer RLY01 with 4 relays is rated for 230V (old one is rated only 30V)
You may need an electrician to do the connection as there may be regulations
 Current time is 08:23 am
