Posts: | 5493 |
Cytech's new version of the Logic Engine, LGX01 has a plug in connector for ETH03 Ethernet interface or USB01 USB Interface which acts as a UCM so another UCM is not necessary. This replaces the part number CM9000-LOG
LGX01 is a Programmable Controller for Automation Applications which can replace PLCs and with the ability to interface to most Home automation Systems including Cytech's IRIO
LGX01 with ETH03 submodule
LGX01 PCB without submodule
Features- 8 inputs, 8 open-collector outputs, expandable to 216 Inputs and 216 outputs
- 12V - 1Amp wall mount adaptor included
- Plug in 10 way connector for ETH03 submodule. This acts like a UCM General, for use with Comfigurator and iOS/Android apps or ComfortClient. Submodule is ordered separately.
- 32 Time Programs
- 1024 Responses
- Sunrise/Sunset Times with automatic daylight saving time changes
- Able to send 250 IR Codes to AV and airconditioners
- Works with all the UCM Interfaces, eg KNX, C-Bus, Ethernet, USB Universal, Z-Wave etc
- Programmable via the ETH03 plugin submodule with Comfigurator
- PCB only. EN01 or EN03 enclosures are available
Applications- Central Controller for AV, Lighting, Blinds, Heating, Airconditioning, Irrigation etc with Scheduling and logic condtitions (If/Then/Else)
- Interface to UCM/Universal, C-Bus, KNX, Z-Wave, Velbus, GSM, Modbus etc
- Interface between 2 systems eg Zwave to KNX etc
- iPhone app to control and monitor system
- Control on/off lighting via two way switches with TWS ( with relay and current sensor)
- Control airconditioning and AV equipment via IR signals (250 codes)
Options/Expansions- Up to 8 UCMs (eg RS232, USB, Ethernet, Cbus, KNX, Zwave, Velbus, Universal, GSM, Modbus)
- Up to 8 IRIO
- Expandable to 96 Inputs/outputs using LEM and SEM, and a further 120 I/O using RIO
This is essentially a Comfort PCB without the alarm, dialer, voice, recording, intercom functions.
Logic Engine Differences with Comfort - It is NOT an alarm system. Inputs trigger Responses, do not activate alarms.
- It is not connected to the phone line and does not auto-answer calls or dial to phones
- Does not have a voice menu or make announcements
- No Message recording and Playback
- No Intercom Functions
- No battery charger, does not need backup battery
Part Numbers
- LGX01 Logic Engine PCB with 12V 1A universal wallmount power supply without enclosure
Link to Cytech Products Page http://www.cytech.biz/logic_engine_controller_pcb.html
Link to LGX01 Manual (In Downloadable Files) http://www.cytech.biz/logic_engine_controller_pcb.html
The UCM/Logic is a low cost controller without Inputs and Outputs but otherwise with the same features as LGX01 http://www.comfortforums.com/forum117/4459.html
