slychiu wrote: Any PIR, smoke, gas, heat detector operating on 12V designed for burglar alarm systems will work with Comfort.
For fire/smoke, do not use 2 wires sensors. 4 wires 12V sensors are needed
You should be able to find many manufacturers or distributors
Hunters have s good selection from various manufacturers http://www.hunters-wholesalers.co.uk/
Hi,I have equation about all sensor or zone input
this zone need dry input I mean PIR sensor assume work 12vdc but out not dry i mean output is voltage this voltage is acceptable for comfort system or not or must be inside PIR sensor relay and output relay connected to zones
please this important before buy any sensor
Regards Last edited on Wednesday Nov 12th, 2014 07:26 am by hasan hadi
