KP04A/KP05A firmware 7.007 (Beta)
 Posted: Thursday Jan 4th, 2018 10:50 am
The new (beta ) Firmware has the following changes;
  1. Backlight turns on when the Keypad speaker comes on to make an announcement or in voice menu. The backlight is turned off after a few seconds when the speaker is turned off. This fixes the issue when the backlight turns off when arming or in voice menu or event log when no key is pressed. Pressing a key already turns on the backlight
  2. Backlight remains on in Setup mode (long press * key) so the backlight does not go off while doing setup
KP06A beta firmware can be downloaded from http://www.cytech.biz/kp06a_firmware.html
KP04A beta firmware can be downloaded from http://www.cytech.biz/kp04a_firmware.html
 Current time is 09:54 pm
