KP06 v6.008
 Posted: Monday Apr 14th, 2014 07:10 pm
The new firmware KP06 v 6.008 has been released This fixes some bugs which have been found
  1. Fixed zone name corruption (eg display "kitchen Kitchen Kitchen.."caused by the following conditions; at least 1 zone name with 16 characters; a zone with name < 16 characters triggered just before the 16 character zone
  2. Up to 15 IDs allowed in the setup menu (but requires Comfort firmware changes)
  3. LED status updated upon reset. Before LEDs were off when KP06 is reset
  4. Supports serial number function. ULT 7.052 firmware is required for this (not released yet)
 Posted: Monday Apr 14th, 2014 10:44 pm
I was expecting to see a serial number?
Attachment: screenshot.png (Downloaded 40 times)
 Posted: Monday Apr 14th, 2014 10:54 pm
Coincidence or what but why has this trashed my UCM # 1
Since upgrade the scan returned this (see attached).
If I delete the UCM and rescan it does not find ID = 1 (Comfigurator 3.8.5).
Is it a coincidence that my KP01 and UCM are both ID 1?
All I did was check for firmware update, go with the update and it scan afterwards. Ahhhhh!
Attachment: screenshot2.png (Downloaded 40 times)
 Posted: Monday Apr 14th, 2014 11:10 pm
Here's another example where my config breaks after upgrade.  Going back to 6.007 and it works OK again.
Attachment: screenshot3.png (Downloaded 40 times)
 Posted: Tuesday Apr 15th, 2014 02:29 am
Ingo suggested that Comfigurator 3,.8.6 might fix as there was an issue with the first scan. So I upgraded from 3.8.5 to this version.
The first time I scanned after reset it still showed as type HDL.  I manually changed the type to "General" though and did a couple of system resets and now the scans seem to work.
Weird!
 Posted: Tuesday Apr 15th, 2014 07:03 am
The problem of UCM#1 being detected as HDL is due to Comfort firmware bug. It is described here http://www.comfortforums.com/forum79/3741.html
The serial number will not appear when you upgrade to 6.008 as the serial number has not been writtten to KP06 yet
New KP06s from the factory will have the serial number
However Comfort firmware 7.052 (not released yet) is required to suport the serial number in KP06
 Posted: Tuesday Apr 15th, 2014 11:02 am
OK understood.  I haven't done a sync though on the keypad; I just updated the firmware so presume the *1 is done automatically during the process?
 Posted: Tuesday Apr 15th, 2014 04:09 pm
It may do a sync if it finds that the vocabulary requires it
Anyway once the new Comfort firmware is available it will not detect HDLanymore
 Posted: Saturday Apr 19th, 2014 06:20 am
I forgot to mention LT 7.052 (not released) is required to support the KP06 serial number display for scanning
 Current time is 02:31 am
