KP06 Firmware 6.004
 Posted: Friday Dec 7th, 2012 11:27 am
  1. Need engineer code to access Setting menu so that users cannot accidentally change the ID and cause a communications Failure
  2. "Factory default" option is incorporated into Setting menu. No longer triggered by holding * key for 6 secs.
The latest KP06 Firmware can be downloaded from
http://www.cytech.biz/kp06_firmware.html?category_id=101
 Posted: Thursday Dec 13th, 2012 01:54 am
Known Bugs
  1. If a KP06 is installed at ID#1 and a 2nd KP06 is connected with the same ID without switching off the power, the ID of the 2nd KP06 cannot be changed using the * menu. The workaround is to reset Comfort. This applies to previous firmware
 Current time is 04:34 am
