Comfort Automation/ Security System Forums > Products > UCM > Ethernet UCM/ETH03 > CSM issue in collecting the comfort address
 Posted: Thursday Mar 8th, 2018 08:55 pm
phil1155
I had this issue of seeing in comfort server manager ( CSM), my comfort ip address blinking constantly. Using wireshark, I discovered that there is no loop in my network and this blinking stops when I disconnect another device on my network.
When this device is connected, I can see that all of my ethernet devices reply to the pc/30303 port and again and adain. Hence CSM  receiving every few milliseconds the right answer from comfort and making the PC /CSM window look likes blinking.
When my other device is out of the network, the answering sequence to CSM /port 30303 from all my ethernet devices only happens once.
But looking at the two wireshark captures, I cannot determine where is the problem. Any idea  on how to solve that?My other device is on the same sub segment, it is a device collecting energy comsumption details ( ecodevice made by GCE electronics).Thank you
 Posted: Saturday Mar 10th, 2018 05:50 am
Does the other device also work on port 30303? and it coould be repeating the replies from ETH03?
CS Manager sends a request to port 30303 on UDP and it should receive a reply from  the ETH03s on the network, even on other subnets (which appears in red)
Even with the blinking you are able to see the correct IP address and port? Are you abel to change the IP and port?
 Posted: Saturday Mar 10th, 2018 02:21 pm
phil1155
Hi chiu,
So with more investigation.. it is CSM app that does renew every milliseconds ish the discover frame on 30303 when the other GCE (brand) device is on the network. So this update frequency does not allow me to change the Comfort IP address.
I used another discovery application from GCE also on 30303 and this one sends only one discovery paquet and all devices replies once only. So the issue seems for me between the CSM app and the reply that specific device sends back to CSM.I cannot see in the sniffing what would be the issue. The discovery frames sent by the two app ( CSM and GCE) are slightly differents.
Note that on this subnet I have 15 other devices including 3 other units from the GCE vendor ( I am assuming that their different module are using the same tcpIP modules.
I also disconnected the switches and router on my network and the problem was still there.
Not a big issue if during regular operations, this call to port 30303 is not used.
I will later make a capture on 30303 to check that there is no discovery frame storm.
Strange.
 Posted: Saturday Mar 10th, 2018 05:58 pm
cc_uk
I also have seen this when there is another similar device on the same network. I wonder whether a change to CSM could be made to discover the devices but not constantly have them flicker so you can't actually select one?
 Posted: Sunday Mar 11th, 2018 05:53 am
Please let us have the screenshot of the wireshark to see why CSM would resend the mesage when this particular devoiioce is connnected
 Posted: Sunday Mar 11th, 2018 08:04 pm
phil1155
Here is the answer frame from that specific GCE device that creates the storm when inserted on the net
Attachment: reponse ecodevice.JPG (Downloaded 8 times)
 Posted: Sunday Mar 11th, 2018 08:09 pm
phil1155
Here is the comfort answer to the discover request
Attachment: reponse comfort.JPG (Downloaded 8 times)
 Posted: Sunday Mar 11th, 2018 08:10 pm
phil1155
The discover request from the GCE App
Attachment: Discover request frame from gce.JPG (Downloaded 8 times)
 Posted: Sunday Mar 11th, 2018 08:12 pm
phil1155
Here is the answer from another GCE device ( but this one does not create any storm)
Attachment: reponse ipx.JPG (Downloaded 8 times)
 Posted: Sunday Mar 11th, 2018 08:15 pm
phil1155
Here the storm of request/answer frames , when the GCE device is in
Attachment: storm.JPG (Downloaded 8 times)
 Posted: Sunday Mar 11th, 2018 08:20 pm
phil1155
and the request from the gce discovery app. Only one request and set of unic answers.
Attachment: requets answers with GCE app.JPG (Downloaded 8 times)
 Posted: Sunday Mar 11th, 2018 08:23 pm
phil1155
My gce devices causing issues is .8
Comfort is .10My PC and the apps are .35
Hope your eyes will be better than mine and detect what is wrong.
Thank you for giving your time
Philippe
 Current time is 01:08 am
