UCM/ETH02 with app?
 Posted: Wednesday Jul 15th, 2015 06:15 am
I have just downloaded the iPhone app. I have a UCM UCM/01 with firmware 7.061    The app is working fine but only to set and unset the system. The control page is completely blank on the phone. Is this because I need to change the UCM01 for a UCM/ETH03? or do I need to alter something else?
Original post from Ghyllwood
UCM01 does not have an ethernet interface, it is an old model with Rs232 interface so it could not be used for the android or iphone app
If you mean ETH01 with the orange submodule, this is not suitable although it may work in certain ways
The UCM/ETH03 is required for android and iOS appssee http://www.comfortforums.com/forum122/4007.html
You can buy an ETH03 module to replace the ETH01 that you have
 Posted: Thursday Jul 16th, 2015 02:06 am
Ghyllwood
Thanks for the info on the ETH03  I am not 100% sure which UCM this is, will the ETH03 upgrade this ucm?   Thanks
Attachment: IMG_0627.JPG (Downloaded 39 times)
 Posted: Thursday Jul 16th, 2015 08:05 am
That is UCM/ETH02you can see the diferences between UCM/ETH03 and UCM/ETH02 herehttp://www.comfortforums.com/forum4/46.html
It may work partially with the comfort apps but it is better to buy the ETH03 plug in which wiil make it fully compatibleYes ETH03 can be used on this UCM06 base
 Current time is 12:10 am
