ETH03 module
 Posted: Friday Mar 28th, 2014 05:59 pm
cc_uk
Is there a minimum UCM hardware revision required to support the ETH03 module?
Will it work on an older series UCM card that has an ETH01?
 Posted: Friday Mar 28th, 2014 08:46 pm
Firstly the UCM has to be one that is flash upgradeable.
Then IMHO it just boils down to whether it fits.  I have on my test kit one of the first GEN flash UCM's that also had a 9-pin serial port on the baseboard.
Whilst Eth1 & 2 fitted quite nicely because they had a cut-out in the PCB, eth3 doesn't so I cant use.
I'm quite sure if it's "flash-and-fits it'll work"!
I'm sure Cytech will confirm or shoot me down in flames thought!
 Posted: Saturday Mar 29th, 2014 11:01 am
Correct
You need a UCM that has flash ie min firmware 5.100
The ETH submodule can be plugged on top
 Current time is 03:52 pm
