UCM2 is not a UCM/KNX2
 Posted: Tuesday Mar 14th, 2017 04:30 pm
davidsilva
Recently, I had some problems with UCM/KNX or UCM/KNX2.
When I try write to EEPROM, I have a error: "UCM 2 is not a UCM/KNX2". And when I try a second time I have a diferent error: "Error writing configurator".
If I try Read from EEPROM, I can but is isn't the configuration what I want.
How can I solve this problem?
Best regards,
Thanks.
Attachment: ERRO CYTECH.png (Downloaded 25 times)
 Posted: Tuesday Mar 14th, 2017 04:57 pm
First do a reset of Comfort and see if the problem still exitis
if so, then do Scan for Modules again and clock Copy to Clipboard below comfigurayro main window
Paste to a text file and send to support@cytech.biz
 Posted: Tuesday Mar 14th, 2017 06:43 pm
davidsilva
Now I'm testing with other Comfort II Ultra and other keypad but the same UCM/KNX2, and the problem still exist. I will sent for your email.
Thanks.
 Posted: Thursday Mar 16th, 2017 09:27 am
Hi David
The General  UCM used for Programming firmware is only 5.192
see attached screenshot
It needs to be upgraded to the latest version 7
However for version 5 UCM firmware you need to have another UCM to upgrade this ucm using the UCM programming cable
see http://www.comfortforums.com/forum4/1782.html
When it has been upgraded to UCM firmware version 7, then this UCM can be used to upgrade Comfort ansd the UCM/KNX2 without the programming cable, just use Comfigurator
If you do not have another UCM/USB or ETH03 perhaps you can borrow a UCM or ask Vestereme to to the upgrade for you
By the way you cannot paste an image onto a post in the forum, it will not accept it and will display garbage
Attachment: Capture.JPG (Downloaded 20 times)
 Posted: Friday Mar 17th, 2017 03:28 pm
davidsilva
I already upgrade UCM firmware, and now I can write to EEPROM UCM/KNX2.
Thanks for your help.
 Posted: Saturday Mar 18th, 2017 06:41 am
This advise is now in a new topic
http://www.comfortforums.com/view_topic.php?id=4660&forum_id=73
 Current time is 05:04 pm
