knx to comfort Exception
 Posted: Tuesday Jan 17th, 2012 06:19 pm
m.khairy
when I add a group address this error appears
Attachment: knx to comfort error.jpg (Downloaded 31 times)
 Posted: Wednesday Jan 18th, 2012 02:18 am
This may be due to old version of Comfigurator or Comfort or UCM firmware.
Which version of Comfigurator are you using? Upgrade to 3.4.0 at least if you are using an older version, go to http://www.cytech.biz/comfigurator.html
Also which firmware version of UCM/KNX and Comfort do you have?
If you are not sure, open your cclx file, go to Modules, and Scan all modules which will discover the versions of all modules then save the result and send to support@cytech.biz
 Posted: Thursday Jan 19th, 2012 10:03 am
m.khairy
comfigurator v 3.3.2.0
Comfort II Ultra v 5.211
ucm/knx v 6.011
ucm general v 5.200
 Posted: Thursday Jan 19th, 2012 02:27 pm
Please upgrade to Comfgurator 3.4.0 which can be downloaded from http://www.cytech.biz/comfigurator.html
and try again
 Posted: Thursday Jan 19th, 2012 08:16 pm
m.khairy
I upgraded to Comfgurator 3.4.0
& the Error is solved
thanks alot
 Posted: Friday Jan 20th, 2012 02:29 am
Thats good
Most exception errors have been fixed with newer versions so using the newest version of Comfigurator is aalways a good idea
 Current time is 06:01 pm
