1 bit Arm to Away group address seems not working
 Posted: Thursday Nov 10th, 2011 04:05 pm
TheMax74
Map 1 bit Arm to Away to a group address seems not working.
Sending "1" from KNX bus to this group, does nothing in Comfort.
Can you check please?
Thanks.
 Posted: Friday Nov 11th, 2011 05:13 am
This is the most commonly used function for KNX which should definately work
Can you send your cclx file to support@cytech.biz
 Posted: Friday Nov 11th, 2011 05:45 am
TheMax74
No, thanks, i will investigate more.
Shure is my mistake.
Thank you.
 Posted: Tuesday Nov 15th, 2011 02:04 pm
Canha
Try updating the firmeware...it worked for me..
 Posted: Tuesday Nov 15th, 2011 02:24 pm
TheMax74
 Posted: Monday Nov 21st, 2011 06:39 pm
Tan121
I seem to have the same problem after updating the firmware. Before it worked fine. Now I have all the modules last firmware and Comfort is sending time to KNX but Night Arming from KNX does not work.
 Posted: Tuesday Nov 22nd, 2011 01:46 am
Did you WRITE to EEPROM for the UCM/KNX?
 Posted: Thursday Nov 24th, 2011 01:40 am
We have confirmed that there is a bug in Comfort firmware 6.006, which causes the 1-bit arm from KNX not to work, see http://www.comfortforums.com/forum79/2571.html
Please downgrade to ULT 6.005 for the time being
We are working on a new firmware release to fix this problem
 Posted: Thursday Nov 24th, 2011 04:43 am
TheMax74
Thanks.
 Posted: Saturday Dec 10th, 2011 03:23 am
We have found and fixed the bug in Comfort which causes the 1-bit arming not to work. Now we are doing intensive testing of the firmware which will take some time
The firmware ULT 6.009 is attached for those who would like to try it out for themselves before the release
See forum for Ultra beta firmware 6.009 http://www.comfortforums.com/forum79/2637.html
 Current time is 10:48 am
