Posted: Saturday Aug 31st, 2019 04:19 pm |
nbexiga
Posts: | 59 |
I have a Comfort SPC II that I did an upgrade of the UCM of the Module via the Comfigurator with latest Version.
I have a ETH01 for connect to the board.
After the upgrade ir got no error, but when I see the keypad it got with no letters on the screen.
I noticed that the Comfigurstor lost the connection to the UCM.
I resented via the reset switch button and it starting displaying again.
But I have no connection to the System now..
I also opened the DSManager but cannot find the UCM
What can I do now?
How can I revert this update or connect to the UCM
I dont have USB to connect directly..
Is it any issue with the Tibbo Board?
Please help me.
Nuno
Posted: Sunday Sep 1st, 2019 02:15 am |
Posts: | 5495 |
The Tibbo is probably faulty. I suggest getting a ETH03 or USB to replace the ETH01 which is more than 10 years old
Posted: Sunday Sep 1st, 2019 08:31 am |
nbexiga
Posts: | 59 |
HI,
Why after the upgrade de KT was with no information on the display?
I had to reset the comfort and after that i start worked.?
probably is any issue with the firmware no?
Where i can get a ETH03 ?
Posted: Sunday Sep 1st, 2019 08:41 am |
nbexiga
Posts: | 59 |
And how can i see now if the firmware was upgraded correctly?
because as i am seeing in the ETH03 manual that the firmware for comfort must be Comfort firmware 7.057 , and i really cannoy connect now to the UCM
Posted: Sunday Sep 1st, 2019 08:43 am |
Posts: | 5495 |
You can buy ETH03 from your usual distributorit is normal to require reset after a firmware upgrade
Posted: Sunday Sep 1st, 2019 08:52 am |
nbexiga
Posts: | 59 |
ok... i will check..
because the ETH01 i purchase from the internet years ago..
i cannot remember from what site.. but i know that was online..
if there is that option now.. i prefer
Posted: Sunday Sep 1st, 2019 09:31 am |
nbexiga
Posts: | 59 |
and if i purchase the ETH03 and still now working?
how can i ensure that is an issue with the ETH module?
how can i troubleshoot that?
any way with to see what firmware is the UCM now?
with no ETH0 access?
because eall seems working as expected .
the lights... the time programs...
everything seems ok , but only the connection i am getting error connecting to UCM
and the tibbo ds manager cannot find any device...
before the upgrade was very good working
Posted: Sunday Sep 1st, 2019 10:39 am |
Posts: | 5495 |
UCM firmware upgrade cannot affect DS Manager
Posted: Monday Sep 2nd, 2019 03:17 am |
Posts: | 559 |
I had a similar issue upgrading my UCM/Ethenet with an Eth01 module. As unlikely as it sounds, DS Manager stopped seeing the module after the upgrade. After a downgrade, using the cable method, it worked again and DS Manager saw the module also.
Posted: Monday Sep 2nd, 2019 10:15 am |
nbexiga
Posts: | 59 |
Ingo,
Thanks for your update.
so i have to buy the USB to connect to the UCM and downgrade the firmware?
What cable method can i do? i only have access by ETH01 now..
Or is it better to purchase the ETH03 ?
It will work with the ETH03 purchase?
Posted: Monday Sep 2nd, 2019 11:39 am |
nbexiga
Posts: | 59 |
Probably it's the new UCM version that is not compatible with the ETH01
Posted: Monday Sep 2nd, 2019 12:51 pm |
nbexiga
Posts: | 59 |
Ingo wrote: I had a similar issue upgrading my UCM/Ethenet with an Eth01 module. As unlikely as it sounds, DS Manager stopped seeing the module after the upgrade. After a downgrade, using the cable method, it worked again and DS Manager saw the module also.
But I dont have any more cable to connect directly to do the downgrade...
Posted: Monday Sep 2nd, 2019 01:33 pm |
Posts: | 5495 |
I suggest to get USB or ETh03 submodule, do not use the ETh01 anymore (which is more than 10 years old and no longer produced)
both should work
Posted: Monday Sep 2nd, 2019 03:22 pm |
nbexiga
Posts: | 59 |
Ok, i will get the new module then. and after that i will test it and advise here if it works.
thanks chiu.
Posted: Thursday Sep 5th, 2019 10:49 am |
nbexiga
Posts: | 59 |
good morning,
the ETH03 will arrive today.
later i will install it and try.
any advise for the installation?
Just replace the ETH01 and connect the new one?
thanks
Posted: Thursday Sep 5th, 2019 12:21 pm |
Posts: | 5495 |
Turn off power to the UCM, remove the ETh01 and plug and mpount the ETH03 on the UCMThen power onUpgrade the firmware on UCM
Posted: Thursday Sep 5th, 2019 01:07 pm |
17th Post |
nbexiga
Posts: | 59 |
Ok, should i connect the cable with the 4 pins to the ucm only right?
Posted: Thursday Sep 5th, 2019 01:28 pm |
18th Post |
Posts: | 5495 |
Remove the white cable to disconnect the UCM from Comfortreconnnect it after plugging in the ETH03
There should not be anbny more wires
Posted: Thursday Sep 5th, 2019 06:34 pm |
19th Post |
nbexiga
Posts: | 59 |
unfortunattly bad news...
now i can see the eth03 and ping it , but the same error after tried Comfigurator..
Failed to connect to ucam - check ucm connection settings..
https://pasteboard.co/Iw2oWCH.jpg
Posted: Thursday Sep 5th, 2019 06:41 pm |
20th Post |
nbexiga
Posts: | 59 |
I did it now!
just updated again configurator
thanks
i will do now a firmware upgrade to see
