It appears like there could be a fault on your system which keeps the telephpne limne open
There is a problem when you leave electronic equipment off for many years - when you finally turn it on, some of the electronic compoents like capacitors may be faulty
Your comfort 2 is probably close to 10 years old (firmware 5.045)
If you return to the factory (Cytech) we can quote you for a repair or upgrade
Otherwise you can bypass the telephone line and not connect to Comfort, and check "Ignore line Cut" but that means you will not be able to dial out or in
