Posted: Sunday Jan 24th, 2016 09:50 pm |
rollem
I have an older comfort II Ultra system that is running V5.113 firmware on an MPU01. The client has bought a new KP04A V7.xxx which does not seem to want to work with this older firmware.
I am trying to upgrade the firmware in order to get the new keypad to work.
The UCM I am using to upgrade the system is running V6.008. There is another UCM in the system with Unknown firmware but I suspect its V5.xxx. There are also two door stations and one KP04 and now one KP04A.
I am using the programming cable method. I have tried with and without the MPU01 on the mainboard. I have also tried with and without the standard comfort bus cable connected.
Each time I get the same error after selecting the new firmware version which says "firmware upgrade encountered a problem"
What am I doing wrong?
Thanks in advance,jon
Posted: Monday Jan 25th, 2016 05:35 am |
Posted: Monday Jan 25th, 2016 11:19 am |
Posted: Monday Jan 25th, 2016 05:09 pm |
Posts: | 5841 |
Can you open the Monitor I/O before starting the Firmware upgrade.
If it fails, Copy to Clipboard and send it to us so we know the cause
Posted: Wednesday Jan 27th, 2016 03:53 am |
rollem
Hi Chiu,
I went back to site today and tried again. This time the upgrade was successful. I have no idea what caused the failure on the previous occasion but it was probably engineer error. Ha!
Thanks for the support.
Jon
Posted: Wednesday Jan 27th, 2016 06:59 am |
Posts: | 5841 |
what, engineers make errors?
