Firmware and Module Problems
 Posted: Monday Jun 16th, 2014 04:47 pm
Podro
I have a Comfort Ultra II running firmware 5.164 with a UCM Type 10 (CBUS) at 5.092 and the UCM Ethernet.
I have 3 keypads and 1 door station.
Basically I am wanting to bring all the firmware up to date and I have also got a problem when I run Comfigurator 3.8.8 telling me the number of modules does not match.
I have tried to follow the instructions from this thread to add the modules manually, however I believe my UCM modules are not set up correctly (as I am showing 8) and when I try to scan those I get the error message that scanning isn't supported.
Where should I start...?
Thanks! :)
Attachment: Comfort.JPG (Downloaded 47 times)
 Posted: Monday Jun 16th, 2014 06:00 pm
What is the firmware of the UCM/ETH The minimum is firmware version 7 to support full module scanning. If your UCM firmware is minimum version 6, it can be upgraded to version 7
If yur ucm firmware is version 5 it is not able to upgrade itself, and needs another UCMM to upgrade it using the UCM firmware cable
 Posted: Monday Jun 16th, 2014 06:59 pm
Podro
I don't know for sure, but I suspect it has never been upgraded since install about 7 years ago so will be an early version.
I will have to arrange for it to be upgraded.
In the meantime with the current setting I have developed a comms failure showing UCM8 which wasn't there before.  How do I restore my system to a stable state pending the upgrade.
I have tried reloading the config file and resetting the system and it is now telling me my user code doesn't have sufficient privileges to do that...
 Posted: Tuesday Jun 17th, 2014 06:56 am
when do you get this message
After scanning the modules, if you find the extra ucms and keypads, manually delete them before writing to comfort
 Posted: Tuesday Jun 17th, 2014 01:58 pm
Podro
I get this message when I try to reset the system of load the comfig file from comfigurator.
I have no comms at the keypad now as they are showing comms failure, so basically I cannot sign into the alarm or gain control.
I also cannot scan the modules so not sure where to start with this really??? :(
 Current time is 06:16 am
