Panel firmware upgrade 7.024->7.026 renders panel dead
 Posted: Thursday Apr 25th, 2013 06:04 pm
steefdebruijn
Tried to upgrade the main panel. It interrupted a couple of times during the upgrade asking to continue at last address (through eth module). After the upgrade the panel is dead.
How do i revive it?
Steef
 Posted: Thursday Apr 25th, 2013 07:00 pm
steefdebruijn
> UB0100FE
< UB01F0
> UB02
< UB02
> UD03FEF0F071F0423DA4984C55B4169BAF5059CCC3D9D6F5FD91D5F9B589652217C10AF35389652217C10AF35389652217C10AF353DC56EC115A022EA104A2DC5120151A6C69DEB8F8C111B7C370C94C25D0A89BF01AD48A19B9BA34A11BC5DD8554F787CDBCE8B45EB130A35EE55BCE9E9613A25243CFE8C7E033A299DBF85596DCACE888005AD01F54666DB90052554A0EDE29C98D68E32C45B3A36F796967507123322C2F416014BE4D6A3AE6D1239CE238681889652217C10AF35389652217C10AF353FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0D
< OK
> UD000000F040A6305C6708278E7385818F35B751773593FBDC7B9F2DAF2891FC6558839683C104B31BE378DD9EBE740C7BE52DDCD829A348BA008F6B7E0F512BD8C8447DE551F577CD33854EBAF1ABBA63C4AE847D85A32CDDD8ECCADB839EB91F9090502C0012FBDF154436DF3869B6D76F6E5F8DCA447EB19EEE1F8954AD5B23EA5A3DBAF4E7FDD338F9E6FBBF9E53B88DB124E90AF6EF0CBE274758503884272A6B23F2315E40A357BF6B26FEE131C297EA08CD2CC24DD90A25FFB1A7DFDA759AA0A20BA3096E6117AD94C3FA73BA1F766011403432988B5977F6EA8923C871F5EF782B7986B23349D5C1DB995EF3783E680B10D6
< OK
> UD006270F0B61EF658AFCF8A244E9BF1235654147F3DB20557DDC44D5B2E4EFB067544EC1B1CC4A6F5C2DE78F0B30EDBB0A76C585D6DFF719B1F8E2F14E22EF13E155659EF831A5931C2989E57BF8694B3506B5E897FD94ABCB149CBE0585984CFFE8E8CDE77292014FA69D19B2ECB2E77C4D5EFAD266B7A63797CE26470D919B6B258C8B1304B711BBDA2CBB56622EC641085FFD570A974DA04BF7F2AF38B688ECEE32E4EA72B2B052EFC5E44C80A1C2ACC07F908E394BCB1F11C2BDDB3F9E774DDCA1B33CBF49ED2A80515C80680DC0C154924A05711BA5BBD247C939BAE96CC89B27051DC71928C7071D2BF585EE85CD503AD7B1B
< OK
> UD006360F0D0328832A3831780CC632A4CA63295E069DD414000744373E3305BE576EDA4ED57B34CE10702DD7888053DC5D7D1115B2FD55C984119DC24F2416118CBC40689BBBE2F0C64C465CDC8B09DC6F75080DE241654F6BC25D39591003806FF1C54D43F08ADC7A73C25DE29887F25BFAE983C3379D7172417ABC8405DCDF190044EE87D610AEDBB9F79A8FB11F0D266ED440415DD6D9F24CEB1B52A2914593A827427BD9A678C357D783AF60F6695C0842FDB51F26C3067D41A3949470273B2BE040B01CA52312BFED309497FA25FC664C27544DEFC456CC0B650FB11F0D266ED440415DD6D9F24CEB1B52A2914593A8274274A
> Kan geen gegevens schrijven naar de transportverbinding: De externe host heeft een verbinding verbroken.
(dutch for can't write data to transport: external host broke connection.)
At this point I get a popup Firmware upgrade timeout. Continue from last address?
It fails at different points in time, I tried multiple times, last time it continued from 17% to 89%.
< NA
< NA
< OK
> UD006450F0F4B431105ECD45EEFFCEF7E502476D8F9B46C6552A3D096B171510590030091D41772E1FA441492B1E0101F85FB14F307F2EDC7E4C2DED3E417B16CFF1C45BF6953870F19FB449342557E907AD83EEA65154FA10E488801B5B37B210360B22C1FB5D9EA1469EAFA60DD3C61501C66EE680DC554C78C2B953176819C2952A1E2D3AC0F28E7A3B6FBA4AE1F28B7B0A963CBC463CA6D4AB8F4DCFD3029B8BBC101D01CA52312BFED309DA7089101E8F17A95E1A660C61B478D44CB3FC82340FA95D1857D6F71B367087BDC1BBAF56D05CEEB7E025580CCE2BC43D45056C3EEDD37F66C6C27EA054D97BD19D9D9879BB58B2AA
< NA
< NA
< NA
< OK
< NA
< NA
< OK
Now i get a popup UCM does not support this operation
This aborts the upgrade procedure
 Posted: Thursday Apr 25th, 2013 08:39 pm
steefdebruijn
Update, **SOLVED**
Tried multiple times. At the end I discovered an IP conflict on my network. After solving this, it went wrong another 2 times, but after that, the firmware loaded OK and the panel started responding again.
Steef
 Posted: Friday Apr 26th, 2013 01:54 am
I am glad you fixed the problem
The Firmware Upgrade  process is normally quite reliable  but occasionally network connections are dropped (especially with wifi) but continue from last address should work
 Current time is 04:14 am
