Posted: Saturday May 26th, 2012 04:20 pm |
strickers
Posts: | 79 |
I have managed to upgrade my comfort ult and my UCM/GSM using UCM/Ethernet, using the cable but how do I upgrade my UCM/Ethernet firmware? as it cant upgrade its self.
Do I need to swap the daughter boards of my GSM and ethernet to make this happen?
Thanks,
Chris.
Posted: Sunday May 27th, 2012 01:55 am |
Posted: Sunday May 27th, 2012 01:59 am |
You cannot upgrade by swapping the daughterboards of ETH and GSM or other modules
GSM firmware and UCM firmware are different. The UCM/GSM firmware are not able to upgrade other UCMs
UCM/ETH, UCM/USB, and UCM/232 have the same firmware on the base UCM
Posted: Sunday May 27th, 2012 09:50 am |
strickers
Posts: | 79 |
OK thanks for your replys. Its at version 5.xx. Is there anyone who is in the same situation? maybe we could help each other out?? Am from the midlands
Thanks,
Chris.
Posted: Sunday Sep 15th, 2013 04:28 pm |
ninotorres
Posts: | 36 |
I have exactly the same dilemma.
Is it possible to upgrade the UCM/eth via the serial port it has? If so can someone point to a link on how to do It?
Nino
Posted: Monday Sep 16th, 2013 01:51 am |
If your UCM/ETH is version 6 or above you can upgrade using Comfigurator 3.6.8, see instructions in http://www.comfortforums.com/forum92/3400.html
IF your UCM firmware is version 5, then you need to use another UCM minimum version 5 with a programming cable to upgrade your ucm see http://www.comfortforums.com/forum4/1782.html
Once it is upgraded to the latest version (v7) the UCM can be upgraded by Comfigurator without needing another UCM and it can also be used to upgrade other UCMs and modules so it is worthwhile doing so. If you do not have another UCM you may be able to ask someone who lives nearby for help, or your distributor who sold the Comfort system to you
