Firmware upgrading old Comfort II and UCM01
 Posted: Monday Apr 30th, 2012 10:22 pm
bodsmate
I have an older comfort II I am about to install (never got round to fitting as an upgrade to my comfort 1) - I am confused about my firmware upgrade options even after reading this forum (I must be loosing it :shock:)
My comfort PCB/Firmware is pictured here
I also have a newer firmware PCB/chip I must have purchased to upgrade it
I have a UCM01/232 with audio with firmware 5.92
What's my most economical route to upgrade to latest firmware?
Thanks for your assitance
 Posted: Tuesday May 1st, 2012 02:02 am
You have the older version of Comfort 2 with non-flashable memory. The MPU01 with firmware 5.087 upgrades that to Flashable memory.
That firmware can now be upgraded to the latest version 6.xxx using a Comfort 2 UCM. You have UCM01 which is the Comfort I UCM which is unable to upgrade Comfort 2 firmware
I suggest that you get a new UCM/USB or better still a UCM /Ethernet version 6 which will be able to upgrade your Comfort firmware as well as itself using Comfigurator, see http://www.cytech.biz/pc_interfaces.html
 Posted: Tuesday May 1st, 2012 08:15 am
bodsmate
Many thanks for identifying my boards - I will do as you suggest and get another UCM
 Posted: Tuesday May 1st, 2012 08:37 am
bodsmate
What is the maximum SCS this system will take (would I end up with Ultra or Ultra II after firmware update?)
I suspect Ultra II is hardware and not firmware but thought I would ask as I don't know what I have got
 Posted: Tuesday May 1st, 2012 09:32 am
I am sorry I made a mistake, I did not look at the photo closely
ULT 5.084 is not a flashable type. You need MPU with firmware 5.100 or higher to be able to upgrade its firmware
Hence you need another MPU as well as the UCM
Once upgraded the system will support 15 SCS and iit will have the same functions as the latest Comfort 2
 Current time is 12:55 pm
