Posted: Sunday Jan 29th, 2012 12:23 pm |
nbexiga
Posts: | 59 |
I have to upgrade my firmware to 6.
but if i upgrade the firmware i don't have the .bin file of the vocabulary that is currently installed and the central.
How can i upgrade the firmware to 6.0 (currently is 5.206 II SPC) withou loosing the vocabulary and have to change all the program again?
Posted: Sunday Jan 29th, 2012 02:45 pm |
Posts: | 5493 |
Upgrading firmware should not affect the vocabulary, firmware upgrade and vocabulary upgrade are separate operations which have nothing to do wth each other
Posted: Sunday Jan 29th, 2012 04:16 pm |
nbexiga
Posts: | 59 |
ok... i'll tried now to proceed with the upgrade but i am not getting...
when i connect the programming cable and insert the jumper in PP2 like in the procedure url... when i turn on the central it get stuck and appear on the Keypad (ID#1 Ver.1.08r) and the keypad is biping constantly and i have no lights on the main board, the rio is blinking red, and the Ethernet is with normal lights.
The thernet is on ID2.
what can be the issue?
Posted: Monday Jan 30th, 2012 11:08 am |
When you remove the programming cable and reset Comfort, is it still working?
What is the firmware on your UCM/Ethernet? This is found by doing Transfer > System Information
Is your UCM a UCM/ETH01 with orange ethernet module or is it UCM/ETH02 with silver like shown below?
By the way it is not necessary to post on multiple places. We monitor all the forums and will replay as soon as we are able. Please continue to reply to this topic
Posted: Monday Jan 30th, 2012 11:26 am |
nbexiga
Posts: | 59 |
I've created another topic because my first question was regarding the Vocab... but after it turns on the upgrade i will still here..
My ETH01 is the one that have the Orange module. and the version 6.002 and UCM TYPE is 10.
Yes, if i take off the cable and do a reset it start working again....
Posted: Tuesday Jan 31st, 2012 12:53 am |
The beeping noise that you described is the normal behaviour when you connect the programming cable This is normal because the Comfort is in firmware upgrading mode and nothing else will work
Did you go ahead with the Firmware upgrade or did you stop there?
You should continue with the firmware upgrade as described in http://www.comfortforums.com/forum4/1216.html
Posted: Tuesday Jan 31st, 2012 06:53 am |
nbexiga
Posts: | 59 |
I dit not proceed because i got the error "cannot connect to UCM" one mote thinh is that while is beeping the red light in the RIO is flashing red....
only one thing that i did not do because i don't know what is.... " SRN terminal block can be removed
"Last edited on Tuesday Jan 31st, 2012 06:54 am by nbexiga
Posted: Tuesday Jan 31st, 2012 07:08 am |
SRN terminal block is the siren connector. During upgrade the siren may be turned on so you can remove it
Just to clarify that the PP2 should be connected on the Comfort not the UCM
Can you turn on the Monitor I/O before trying again to do the upgrade
then save the monitor I/O and send to us
Posted: Tuesday Jan 31st, 2012 08:39 am |
nbexiga
Posts: | 59 |
yes the PP2 is shunted on the comfort.
when i connect the cable and the shunt and after turn on the central i'll put th I/O monitor on and see what i got , after that i'll update here with that info.
when i arrive home after the work i'll do that and post.
thanks
Posted: Tuesday Jan 31st, 2012 10:13 pm |
nbexiga
Posts: | 59 |
Now i did some tests. before the programming cable connectes i did the system info.
After that i turn off the central and connected the programming cable and shunted PP2, turn on the central and forced the firmware upgrade file ULT6_011.cbf and got this screens
Before send the file for the central with the cable connected i did system information only and got that cannot connect to the UCM
Resuming.. because it was giving me that error connecting to UCM i did not proceed with the firmware upgrade , but now i proceed with the upgrade the messages are different.. product number...
Can you please advise for wich version of firmware do i have to upgrade this central to get iphone working
Many thanks
Posted: Wednesday Feb 1st, 2012 11:04 am |
The problem is that your system is SPC firmware but you are trying to upgrade to ULT This is not allowed hence the message Product Type Does not Match
Firmware camn only be upgraded to the same type
Try upgrading to SPC 6.011 attached
Your UCM will also need to be upgraded to the latest
Attachment: SPC6_011.zip (Downloaded 7 times)
Posted: Wednesday Feb 1st, 2012 11:17 am |
I have renamed this topic Upgrade of SPC Firmware instead of Upgrade to the Vocabulary
Posted: Wednesday Feb 1st, 2012 11:37 am |
nbexiga
Posts: | 59 |
Ok, later when i arrive home i'll try this firmware that you post.
regarding the UCM upgrade , are you refering to the Ethernet UCM right?
if yes for wich firmware should i have to upgrade to?
and i will be able to upgrade the Ehernet UCM firmware with the boards that i have? or do i have to have a USB board to upgrade the Ethernet board?
Many thanks for your help so far! hope i will have Iphone working
Posted: Wednesday Feb 1st, 2012 11:55 am |
nbexiga
Posts: | 59 |
ident wrote: I have renamed this topic Upgrade of SPC Firmware instead of Upgrade to the Vocabulary
Ok, thanks.
It make more sense
Posted: Wednesday Feb 1st, 2012 12:22 pm |
Posted: Wednesday Feb 1st, 2012 02:17 pm |
nbexiga
Posts: | 59 |
haaa ok , after i upgraded the central i'll try to do it in the Ethernet. like this way you mencioned
i'll updated you when i back home. ;9
thanks
Posted: Wednesday Feb 1st, 2012 07:29 pm |
17th Post |
Posted: Wednesday Feb 1st, 2012 07:37 pm |
18th Post |
nbexiga
Posts: | 59 |
Hi have the ETH01 ... ive tried to upgrade the firmware to 6.008 but it gives me that this version is not for that module....
for which firmware should i have to upgrade?
Posted: Wednesday Feb 1st, 2012 07:49 pm |
19th Post |
nbexiga
Posts: | 59 |
OK DONE BOTH!!
NOW EVERYTHING IT's oki!!!!
MAny thanks for the HELP!! Really appreciated!
Have a very nice day!Last edited on Thursday Feb 2nd, 2012 01:12 am by ident
Posted: Wednesday Feb 1st, 2012 08:39 pm |
20th Post |
rportela
Posts: | 24 |
Hello,
I have exactly the same versions, but I have a LEM board on top of the Confort.
Can I just unplug this board (including flat cable) to do the connections, and the upgrade ?Attachment: board.jpg (Downloaded 60 times)
Current time is 09:34 pm | Page: 1 2 |
