GSM Firmware Upgrade Fail
 Posted: Friday Oct 7th, 2011 08:24 am
raygregg114
Hi, as you can see when I do a scan of the UCM's the GSM comes up with no version.
Attachment: Comfort 061011_2.PNG (Downloaded 38 times)
 Posted: Friday Oct 7th, 2011 08:28 am
raygregg114
Hi, When I try to upgrade the firmware I get a failure, now comfort displays UCM2 on the keypad and says SMS failure with the green light blinking.
Attachment: Comfort 061011_1.PNG (Downloaded 35 times)
 Posted: Friday Oct 7th, 2011 08:44 am
What is the firmware version of the UCM/GSM that you are trying to upgrade with the file GSM 6.005 and how are you doing that, with the programming cable or the method of Upgrading by Comfort Bus?
Upgrading by Comfort Bus is only possible if the module is already version 6
If the module is version 5, then you have to use the programming cable
Scanning the UCM can only show the firmware version if the firmware on the GSM is already 5.201 or above see http://www.comfortforums.com/forum98/2405.html
So it does not mean your UCM/GSM is not working when it does not report its version
So if you have a UCM/GSM which is less than version 6, you need to use the UCM Programming Cable to upgrade to version 6, see instructions at  http://www.comfortforums.com/forum4/1782.html
After the upgrafe you will be able to upgrade firmware using the Comfort us method and without needing the Programming Cable as described in http://www.comfortforums.com/forum92/2409.html
 Posted: Friday Oct 7th, 2011 07:14 pm
raygregg114
KP03 Keypad, is there a firmware upgrade for this as it is showing up as UNKNOWN?
 Current time is 03:11 pm
