VPN
 Posted: Friday Aug 5th, 2016 09:46 pm
strickers
I have changed my system to now use the eth03. With my old eth I could VPN into my home network and use the android app with comfort. I am using the latest app and now when I VPN in the app cannot talk to comfort but works fine when I am at home on the local network.
I do not want to forward any ports and only want to have remote access to comfort when the VPN is active.
Any ideas?
Thanks.
 Posted: Saturday Aug 6th, 2016 05:30 am
Why would any local IP address not work with VPN?
Does any VPN expert have any idea?
 Posted: Sunday Aug 14th, 2016 04:07 pm
strickers
A bit more info. When I VPN into my network I can ping all the other devices on the network apart from eth03. I have made sure the ip, gateway and subnet are all correct. When I try and ping eth03 at home (local) then it pings fine. Could this be something to do with the routing mode option or transport protocol?
Any ideas?
Thanks.
 Posted: Monday Aug 15th, 2016 10:55 am
Swiss-Toni
the local ip address usaully starts with 198.***.***.*** if your outside of the local network you will have to use the IP address for your WAN
 Posted: Monday Aug 15th, 2016 11:02 am
That 192.168... right?
 Posted: Monday Aug 15th, 2016 02:13 pm
strickers
Hi, Thanks for the reply. When the VPN is active you get a local 192 address so should be able to use the static address. I can ping the other local addresses in the network via the vpn
 Posted: Monday Aug 15th, 2016 05:43 pm
what does not work, Comfigurator or the Comfort app?
did you try both?
 Posted: Tuesday Aug 16th, 2016 09:28 am
Swiss-Toni
The vpn still has to be set with a static wan address and your router must be configured tcp forward you will have to check you have the etho is within tcp range for your vpn
 Posted: Tuesday Aug 16th, 2016 09:31 am
Swiss-Toni
Try using the same lan address as your old etho
 Posted: Friday Aug 19th, 2016 07:33 pm
strickers
Thanks Tony that seems to have fixed it. not sure how tho :)
 Current time is 10:25 am
