Posted: Thursday May 14th, 2015 11:48 am |
Posts: | 5499 |
The new Comfort android app v 1.4!
Posted: Friday May 15th, 2015 02:31 am |
wexfordman
Posts: | 546 |
I can't change an icon.
When I select the device (bedroom light for example ) to change, nothing happens, it doesn't move to the select icon screen
Posted: Friday May 15th, 2015 03:55 am |
CytechMartin
Posts: | 47 |
For example, if you want to change the icon of bedroom light, you need the click the icon of the bedroom light, but not the text "bedroom light". So that you can move to the icon select page.
Posted: Friday May 15th, 2015 07:43 pm |
wexfordman
Posts: | 546 |
CytechMartin wrote: For example, if you want to change the icon of bedroom light, you need the click the icon of the bedroom light, but not the text "bedroom light". So that you can move to the icon select page.
Yeah, but there are no icons against the light when I go in via the spanner option.
The icons only appear when I am logged in as a user , not when I go to edit a configuration
Posted: Saturday May 16th, 2015 06:25 am |
Posts: | 5499 |
Once you press the Spanner, you see the page with setup control icon on top
Select one of the Groups, then you should see the text on the left and icon on the right as in the picture 4 above. Pressing the icons reveals the list of icons
What exactly do you see ?
what phone and OS do you have
Posted: Saturday May 16th, 2015 11:36 am |
wexfordman
Posts: | 546 |
I have a HTC one m8 using android 5.01
Here is what I see[size= ][size= ][size= ][size= ]
Posted: Saturday May 16th, 2015 12:10 pm |
HeFeng
Posts: | 29 |
Hi, Waxfordman, can you download a comfort tablet version 1.4 to try this issue by using your HTC phone? thanks for it!
Posted: Saturday May 16th, 2015 12:29 pm |
wexfordman
Posts: | 546 |
Same thing, Ihave no icons. There are none when I log in as a user either in either phone or tablet
Posted: Saturday May 16th, 2015 01:04 pm |
Posts: | 5499 |
Perhaps it is a Lollipop issue
How about the rest of the operation, is it working well?
Posted: Saturday May 16th, 2015 02:02 pm |
Posted: Sunday May 17th, 2015 07:10 am |
Posts: | 5499 |
We have generated a test which should work for Lollipop
which you can download from http://www.cytech.biz/product_details.php?item_id=373
You can unzip the apk and install on your phone
However you will have to uninstall the app before installing it and re-enter the data from the attachment, if you do not mind doing that
Posted: Sunday May 17th, 2015 11:12 am |
Swiss-Toni
I have exactly the same issues with a samsung S4 running 4.2.2
However I do like the direction that this App is now taking with all the custom-ability of it and appreciate the work that has gone into designing it.
Posted: Sunday May 17th, 2015 11:52 am |
wexfordman
Posts: | 546 |
slychiu wrote: We have generated a test which should work for Lollipop
I did that and exact same thing happening unfortunately]Last edited on Sunday May 17th, 2015 11:54 am by wexfordman
Posted: Sunday May 17th, 2015 09:48 pm |
I'm seeing another issue.
I load in the new config and it works fine in the UI. But when I next restart the APP the config seems to have disappeared again and all I get is the CONTROL menu (empty) when I log in.
Seems not to remember I've added the config.
Posted: Monday May 18th, 2015 06:22 am |
Posts: | 5499 |
Those who cannot see the buttons in setup please send the cclx files to support@cytech.biz It is not a problem with Lollipop b ut it may be certain aspects oof the control menu
Posted: Monday May 18th, 2015 06:24 am |
Posts: | 5499 |
Could it be that you checked the button for Control Only? This hides the alarm pages
Posted: Monday May 18th, 2015 10:00 am |
17th Post |
Posted: Monday May 18th, 2015 02:31 pm |
18th Post |
wexfordman
Posts: | 546 |
Sent my logfile as requested.
Regards,Eamon
Posted: Monday May 18th, 2015 05:37 pm |
19th Post |
Posts: | 5499 |
We have tested your file
There are a few problems with the control menu
In the control actions, Comfort feedback expects key 0 to be OFF and 1 to be ON
Yours is the reverse is 1 is OFF and 0 is OFF
what you have done will give the wrong feedback
If the counter value is 255 the status should be ON, and the system uses the text for key 1 which in your case is Office Light Off
The keypad and phone voice menu works in the same way, 0 must be ON and 1 must be ON otherwise the status is reversed.
This also coincides with a state of 0 and 1. People expect 0 state to be off and 1 state to be on,not the other way round
The other problem is that for the symbols for off and on to work, the text in 0 and 1 should be Off and On respectively, not Kitchen Light Off and Kitchen Light on
If the control key is Kitchen Light, then it is not necessary to again use text Kitchen Light Off and Kitchen Light ON, Off and On is sufficient
The suggested order of the control menu is as below
In your original program, the control menu wlll not show the icons for off and on, instead you will see the text for the feedback only
In the revised format of 0 for off and 1 for on, the app will show as below
Notice the Kitchen light has changed from text to icon. I did not reprogram Kitchen and family room etc
Posted: Monday May 18th, 2015 05:54 pm |
20th Post |
wexfordman
Posts: | 546 |
Brilliant
Makes sense now, I will revise and upload ta new menu tonight.
Thanks,
Eamon
Current time is 01:09 pm | Page: 1 2 |
