Wiser Control Unit
 Posted: Tuesday Mar 30th, 2010 04:55 am
Howser
There are two widget types available for in Clipsal Wiser, being MinderPro and Homesafe.
My question is, does the Security Widget (I assume MinderPro) work with Comfort?
If so, does it expose all the functionality, Arm/Zones/Trouble and so forth?
Are there any firmware requirements from Comfort side?
Howser
 Posted: Tuesday Mar 30th, 2010 05:28 am
MinderPro or Comfort should work with Wiser. We have not used Wiser buy what we know is that it uses the C-Bus security application which Comfort/MinderPro complies to, so almost everything defined by the security application is visible on Wiser.
 Current time is 01:33 pm
