when arming to Day Mode via PICED, it fails to arm if ANY of the zones are open. I wonder if there is a 'force-arm' function in PICED that can be used, as far as I can tell there are none. This puts us at a bit of a disadvantage, with ComfortClient, and any software that sends either the m! or M! command, you can choose to force-arm with open zones or not.
Especially in Day Mode, I like to be at home, with some open zones and still have some protection. How would that be accomplished via PICED or is that another thread that needs to be started?
This picks up the thread from http://www.comfortforums.com/view_topic.php?id=937&forum_id=11
Arming from Piced using SystemIO issues a Key Arm command similar to m! from a UCM
Open zones are indicated via the Arm Not Ready status which can be shown on C-Touch
Force arming can be accomplished by sending the "#" key (key 23) using keypad emulation, while the system is being armed and announcing open zones
