KP06 and SCS
 Posted: Saturday Jun 29th, 2013 11:48 pm
paulgw
Hi all,
I am looking to mount a kp06 and an SCS in the same frame - is this possible? I seem to remember seeing a picture of such a configuration not sure if this was done by using custom frames etc.
Can someone also tell me where I can buy the 3 gang back boxes in the uk?
Would I need to run two cat5 cables to this combination or are they daisy chained?
Any info people can share on how to install system 55 would be really appreciated.
Paul
 Posted: Sunday Jun 30th, 2013 08:52 am
I have seen 1 gang stackable backboxes that can be clipped together to form multigang
The round backboxes are not suitable as the PCBs require more room that allowed by these
 Posted: Monday Jul 1st, 2013 09:55 am
wiredhome
You need a GIRA backbox and frame
part no 2883 20X
X IS THE MATERIAL OF THE FRAME
1= WHITE
2= S/S
3= ALUMINIUM
Contact http://www.knxshop.co.uk
regards
Niall
 Posted: Tuesday Jul 2nd, 2013 04:09 pm
paulgw
Hi Niall,
Thanks for the reply, I had been looking at that part but was put off when it said E22 on the website - are System 55 and E22 the same thing just by a different manufacturer?
Also this is going in a solid wall, are there any versions for solid walls? If not can it be used like a standard UK dry linning box?
Many Thanks
Paul
 Posted: Wednesday Jul 3rd, 2013 12:34 pm
wiredhome
Hi Paul
System 55 is a range of devices made by Gira
they then have a range of frames for them
ie: event,esprit,e2 e22 etc
System 55 is taken from the dimensions of the devices 55 x 55 mm
a standard uk back box won't work for you on this
If your fitting the 2883 20x box in a solid wall you will also need part no. 289300 I think there about 8 euro
let me know if you want them
regards
Niall
 Current time is 07:22 am
