KP06 broken?
 Posted: Wednesday Apr 10th, 2013 06:15 am
steefdebruijn
My new keypad works normally (sound, keyboard, LCD backlight), but does not show any messages on its LCD display. The display stays blank.
Is it broken?
Steef
 Posted: Wednesday Apr 10th, 2013 12:58 pm
can you try pushing in the lcd module
the lcd and keypad modules are removable, so they may be loose after shipping
 Posted: Sunday Apr 14th, 2013 09:41 pm
steefdebruijn
Tried to push module. Also tried to remove it and place it back. Also tried to place back in vertical orientation mode.
All with same result. No display, working backlight, working keypad and sound.
 Posted: Monday Apr 15th, 2013 03:17 am
It appears to be a problem with the LCD internal cconector
The KP06 will need to be replaced
Can you contact your distributor for replacement
Can we have the serial number of the KP06 please, it is on a label with a bar code starting with C or P with 6 digits
Aplogies fro the problem
 Posted: Thursday May 9th, 2013 09:43 am
steefdebruijn
Hi ident,
You have PM with my serial number.
Steef
 Current time is 10:39 pm
