KT03 7.070
 Posted: Sunday May 24th, 2015 07:17 am
KT03 7.070
Known Bugs
  1. IR Receive in KT03 does not work
  2. Display of Output status above 64 does not work
Changes
  1. Supports Zone Name Element (requires Comfigurator 3.10.4), see http://www.comfortforums.com/forum90/4218.html
  2. Supports KT03 System Properties (Beep On/off, Speaker On/Off, Announcements On/Off, Screen Timeout, Backlight On/Off, IR Receiver On/off, Speaker Internal/External, Tamper On/Off) which were only accessible via the KT03 settings screen, can now be changed in Comfigurator. KT03 System Properties Read and Write without having to read/write all of KT03 will be  supported from Comfigurator 3.10.4 See http://www.comfortforums.com/forum90/4216.html
 Posted: Monday May 25th, 2015 05:06 pm
KT7.069 has been replaced by KT7.070 (beta). 7.069 has a bug in write to KT03
Those who installed 7.069 please upgrade to 7.070
KT03 7.070 is released
 Posted: Saturday Jul 11th, 2015 10:06 am
Please note that a bug may have been found in KT03 firmware 7.070 - the IR receive function does not work. This is being investigated. Those affected should downgrade to the last released firmware KT03 7.053
 Current time is 07:20 am
