Posted: Friday Aug 17th, 2012 04:22 am |
- Implemented full features of UCM
- In Settings, add enable/disable of Broadcast announcements, and Tamper
- Turn off Backlight for a few seconds at reset
- Improved Upgrade firmware by direct connection
- Fixed Bug in Portrait Orientation display
Effective 1 August 2012
Note that firmware on systems that are purchased from distributors may not have the latest version due to the supply chain. Firmware for KT03 can be upgraded using a UCM by Direct Connection to PC, see http://www.comfortforums.com/forum4/2283.html
The firmware file can be downloaded from http://www.cytech.biz/kt03_firmware.html?category_id=101
Posted: Friday Aug 17th, 2012 08:25 am |
bs85
Posts: | 90 |
Hi Ident,
Tried to upgrade my KT03 with this firmware and get a message that Product number or type does not match.
Brian
Posted: Friday Aug 17th, 2012 11:41 am |
To upgrade firmware on KT03 you need to be connected to its USB port
In Options > Settings, select the USB port of the KT03. If you have a UCM/USB, you will see 2 USB serial numbers
Then check "Via KT03" box
I suspect you have selected the UCM, not the KT03 USB. This is why you get the error "Product Type does not match"
Posted: Friday Aug 17th, 2012 12:19 pm |
bs85
Posts: | 90 |
I missed the bit where the UCM interface had to be set to USB and via KT03 had to be selected to update the firmware of the KT03.
All done and working now.
Thanks.
