Comfort I vocabulary
 Posted: Thursday Mar 1st, 2012 05:26 pm
paulgw
Have been programming my Comfort I system for a simple alarm using the latest version of comfigurator and every time I transfer the cclx to the panel i get a warning about the vocabulary versions being different.
How do i tell which vocabulary I have in the panel?
Also when the keypad announces Zone x trouble it sounds like treble, not sure if this is related or if that is how it normally sounds?
Paul
 Posted: Friday Mar 2nd, 2012 02:07 am
Comfigurator > Modules & Settings > Misc Settings > Wordlist shows teh vocabulary used for the wordlist. The option should be Standard Residential or UK Residential for Comfort I
Your Comfort may have UK residential but your cclx template may be set to Standard  Residential
Change the selection to UK Residential and try agaiin
The pronunuciation of the words is not affected by this. The wordlist is to match the wordlist used forr zones and Home control menu in Comfigurator to the actual voice in Comfort
 Current time is 06:25 pm
