Posted: Saturday Nov 19th, 2011 09:49 am |
bryanajones
Posts: | 54 |
I have an old comfort 1 system running firmware outside 4.132. I have a serial UCM01 attached bought at the same time as the system. Is there anyway I can use comfigurator to read and write to this comfort 1 system?
When setting up comfigurator 3 I didn't know which system template to choose. I think I did get some reads but also got some form of error saying this system couldn't be written to?
Any help would be appreciated as I have only a few days to strip this system back to a basic alarm only.
Bryan
Posted: Saturday Nov 19th, 2011 12:48 pm |
You can convert your old ccl file created using Comfigurator 2, to the cclx file format used by Comfigurator 3
Comfigurator 3 can read ccl files by specifying Files of Type.. choose ccl
Then Save as cclx
You can open the file as cclx in future
Posted: Saturday Nov 19th, 2011 09:01 pm |
bryanajones
Posts: | 54 |
I've never used comfigurator with this system before. Are you saying that comfigurator 2 will work ok with a comfort 1?
Bryan
Posted: Sunday Nov 20th, 2011 01:07 am |
I thought you were already usiing Comfigurator 2.
I suggest you use Comfigurator 3 Choose Comfort I Pro as the default template
