Latest UCM/USB with old Comfort I Ultra
 Posted: Monday Oct 24th, 2011 02:21 pm
Howser
Would I be able to use the latest UCM/USB to transfer a configuration from Comfort I Ultra (Action 4.227) using Comfigurator 3.3.3.0?
 Posted: Monday Oct 24th, 2011 02:53 pm
Yes that should be able to work
 Posted: Monday Oct 24th, 2011 05:16 pm
Howser
Thanks.
My next question is, besides the file system described here... http://www.comfortforums.com/forum92/2122.html, is there any automated conversion process from a Comfort I configuration to Comfort II?
 Posted: Tuesday Oct 25th, 2011 02:32 am
Yes you can easily convert a comfort 1 config to Comfort 2 using File > Convert File System
You can convert a Comfigurator 2 ccl file to Comfigurator 3 using File > Save as cclx
 Posted: Wednesday Nov 16th, 2011 04:50 am
Howser
I am using Configurator V3.3.3.0 and when I try Convert File System Version to (from Comfort I Ultra : 24) to
(Comfort II Ultra) 34, I get the attached error.
Attachment: Comfort Convert Error.jpg (Downloaded 48 times)
 Posted: Wednesday Nov 16th, 2011 05:28 am
Can you send the file you tried to convert to support@cytech.biz
 Posted: Wednesday Nov 16th, 2011 05:33 am
Howser
File sent to support@cytech.biz.
 Posted: Thursday Nov 17th, 2011 11:41 am
We are looking at the error thanks
 Posted: Friday Nov 18th, 2011 07:15 am
There was a missing parameter in Sensor Responses, perhaps because your original file was too old or was corrupted
The corrected file has been sent to your email
Please test and let us know
 Posted: Friday Nov 18th, 2011 09:03 am
Howser
Thanks, will do once I have the file and let you know.
 Posted: Monday Nov 21st, 2011 05:20 pm
Howser
Got the file and tested the convert. No errors. Will make some time and load it.
Is it safe to load the edited Comfort I project into the old Panel?
 Posted: Tuesday Nov 22nd, 2011 01:49 am
I am not sure which you refer as the old panel, do you have a new and old panel?
Comfigurator 3.3.3 will prevent you from writing the wrong file system into a Comfort
 Posted: Tuesday Nov 22nd, 2011 06:59 am
13th Post
Howser
File System 24 into Comfort I (the old panel).
 Posted: Tuesday Nov 22nd, 2011 11:10 am
14th Post
You can write the file to Comfort 1 Pro if it is File system 24 and have not converted to File System 34 (for Comfort II Ultra)
 Posted: Wednesday Nov 30th, 2011 01:20 am
15th Post
Howser
I managed to load the converted project into the Comfort II panel. All looks good.
The only thing I noticed (in the event logs) was two events (one after the other) are announced for each user signin, am I doing something wrong?
 Posted: Wednesday Nov 30th, 2011 04:00 am
16th Post
No events sometimes seem repeated, but it is normal
 Current time is 11:07 pm
