Comfort Automation/ Security System Forums > Support > Problems & Troubleshooting > Comfort I Issues > Hi New Comfort owner I can't get system information sign in code ?
 Posted: Friday Feb 5th, 2010 08:19 am
the1beard
Hi Guys
chip on UCM5.63 chip on Cbus 5.66
I'm trying to integrate with my cbus system.
I've run comfigurator but when I request system information and enter 1234 sign in code I just get LU00.
Any ideas?
 Posted: Friday Feb 5th, 2010 08:34 am
LU00 means the sign in code you used (1234) is wrong
You need to use the sign in code for Comfort
1234 was the default code when Comfort is shipped from the factory. Have you not changed your sign in code. Your system UCM 5.63 and Cbus 5.66 are about 7 or 8 years old so I hope you have changed the sign in code during that time
 Posted: Friday Feb 5th, 2010 09:08 am
the1beard
Hi Slychiu
Thanks for your reply
I see the problem now.
The system was installed by my father who died last year and I've moved into the house with my family I don't think he ever got around to finishing the install I guess he changed the code but I don't know what code he used.
I also don't have any of the manuals for the system it's a 5300 Series Clipsal Controler. Model 5300TCU8/8
Is there a way of reseting back to factory defaults?
Paul
 Posted: Friday Feb 5th, 2010 10:17 am
The 5300 series Clipsal Controller (Minder Pro) is Comfort I Pro
You can reset the user code back to 1234 using the keypad. Press F0 followed by 6789# (provided the default Engineer code has not been changed). Then press 5 for User Codes, 0 to erase mailboxes and 1 to confirm.
The Comfort I user manual can be downloaded from here
 Posted: Friday Feb 5th, 2010 04:41 pm
the1beard
Slychiu
Many thanks for the info.
 Posted: Monday Feb 8th, 2010 04:27 pm
the1beard
Hi Slychiu
I tried over the weekend with no luck it looks like my dad changed the engineer code.
What are my options?
 Posted: Tuesday Feb 9th, 2010 12:27 am
You can buy a U4 EEPROM for FS24 with default configuration which means the code will be 1234. However that means that your programming will have to be redone.
send an email to support@cytech.biz
 Posted: Tuesday Feb 9th, 2010 03:47 pm
the1beard
Slychiu
Thanks I'm not worried about the programing I don't think my father did very much as he didn't get it finished before he became ill.
There are still sensors which have not been connected so it's a bit like a complete new install for me.
I was going to rip it all out and just get a standard alarm and leave the cbus lighting separate.
It's unfortunate he didn't leave the paperwork and I've ended up with this problem.
I'm away for a month for work I'll get back to you when I return.
Many thanks
 Current time is 05:44 am
