This applies to Comfort I and Comfigurator 2 only
In Comfort I from firmware 4.233 onwards please check the box "Use Branch Actions" in Configuration > Modules & Settings if you use Comfigurator 2. This allows If/Then actions to work correctly for nested If/Then conditions.
For example, see the Response below. If Use Branch Actions is not enabled then the response will not work as expected.
If you have Comfort I Firmware < 4.233 and you nbeed to code aq complex nested If/Then Response, then you are advised to get a firmware upgrade to 4.234 which is the last released Ultra I firmware
If SecurityMode = SecurityOff Then
AutoArm AwayMode
Else
If SecurityMode = AwayMode Then
If AlarmState < Alarm Then
AutoArm SecurityOff
End If
End If
If SecurityMode = NightMode Then
AutoArm SecurityOff
End If
End If
If SecurityMode = VacationMode Then
AutoArm SecurityOff
End If
End If
End If
