Ulti - same as Radiobus?
 Posted: Saturday Apr 14th, 2007 04:21 am
mgfair
I am using a RF lighting and blind controller from Jung (http://www.jung.de); it is called Radiobus.    It is the same type of product as Ulti - I believe it uses the same frequency range but I guess the modulation is slightly different.
Is there a plan to create a Radiobus UCM?
 Posted: Saturday Apr 14th, 2007 05:12 am
Clipsal developed an RF interface to the UCM for us,  as the UCM/Ulti allowing Comfort to send RF commands to the Ukti switches.
Jung does not have a similar interface. RF signals unlike infrared cannot be learned and are generally not compatible with signals from another device even if the frequencies are the same.
A brute force method to get an interface would be to open up their remote control, connect the contacts to relays driven by Comfort. The outputs can be pulsed to activate the buttons to control their switches.
 Posted: Saturday Apr 14th, 2007 10:22 am
mgfair
I assume that Jung/ Berker and the other manufacturers that use the Radiobus are not intereted in producing an interface?
Your brute force method is an interesting idea.    That may be the way to go in the interim.  However, the Radiobus system also has a central controller called FMC1000 which I have installed.    This central controller has an RJ45 interface port.    I wonder if that would enable a more professional way of connecting it all up?    I suppose it depends on the function of this port and its protocol.     Let me raise with Jung.
 Posted: Monday Apr 23rd, 2007 08:01 pm
ndh
Have you spoken with Colin Price at Ivory Egg yet? The've just taken on Jung products.
Nigel
 Current time is 07:21 am
