Reduce PIR sensitivity when armed
 Posted: Wednesday Aug 8th, 2018 08:42 am
Pharris15
Hi all, I use my PIR's for occupancy detection during the day so they are set to be sensitive, but I need to reduce the sensitivity when armed as they occasionally trigger a random alarm which I put down to insects. I looked at the VibrationAnalyse response but I am not sure how to implement this for the PIRs when the system is armed to night or away.
Any help would be appreciated.
 Posted: Wednesday Aug 8th, 2018 11:51 am
The Vibration Analyser Response works as below;
Timer 8 is for timing and counter 7 for counting
If at least  2 counts are detected within 30 seconds, the alarm is triggered
you can change the timer setting of 30 seconds and the count of 2 as you need
If Timer Timer08 = 0 Then
    Do NullResponse After 30 Seconds Using Timer08
    Set Counter007 = 0
End If
Increment Counter007
If Counter Counter007 >= 2 Then
    Stop Timer Timer08
Else
    Skip Alarm
End If
At each zone trigger, the timer 8 is started and count is reset if timer 8  was not running
The counter is incremented. If the value < 2 the a;arm is skipped
If the value is >=2 the timer is stopped and the alarm is not skipped, ie alarm is activated
To add the condition if security is armed then activate the analyser;
If SecurityMode <> SecurityOff
       Set Counter007 = 0
    End If
       Stop Timer Timer08
   Else
    Skip Alarm
   End If
End if
 Posted: Monday Aug 13th, 2018 10:37 am
Pharris15
Hi Slychiu and thanks, the problem I have now is that the zone still announces at every trigger but the alert isn't activated until two triggers (as set).Can the announcement only be made when the actual alert is triggered?
 Posted: Monday Aug 13th, 2018 11:44 am
That makes it more complicated, nut you can add the condition "Skip announcement" in the response. Skip announcement " will skip the announcement of the zone
 Current time is 10:31 pm
