Comfort Automation/ Security System Forums > Support > Questions on Using Comfort > keypad announcement changes caused failure
 Posted: Friday Nov 10th, 2017 01:33 am
caravanboy
I have read other forum posts about disabling the keypad "night mode" voice so I was experimenting with that. I have a Response that (for test purposes) I am initiating via SMS from the GSM4 module:
Keypad AllKeypads Broadcast Disable
AutoArm NightMode
Wait 15 Seconds Using Timer01
Keypad AllKeypads Broadcast Enable
That worked and the keypad voice did not announce "Night Mode". The system still did the main Speaker arming beeps but I plan to later temporarily disable those using an Output and Relay as someone suggested on another thread.
I then used another test response to go to SecurityOff mode - AutoArm Security Off
However, when I did the security off there was NO announcement from either of my keypads, but the security did go to Off.  Do you have any clues why not?
Also, at this point I could then not connect to the system using Comfigurator, yet I could ping the UCM/ETH03 on the network. Also, Comfort Mobile connected okay on the local LAN and showed live zone movements but attempting to change security mode did nothing. Also, using the Night mode key on the keypad did nothing. Keypad menus worked as normal. I ended up having to use engineer mode 7,4,2 to do a system reset and then all was fine again.
My wife has gone to bed now so I can't do further testing tonight but is there anything obviously wrong with my Keypad broadcast method above?
 Current time is 12:37 pm
