Posted: Monday Feb 16th, 2015 09:32 am |
dcrera
Due to load shedding and a technical fault on the AC supply, I have decided to run my system on battery power using a backup UPS.
The system is working perfectly well.
However I want to disable the 'POWER FAILURE CONTROLLER' message from displaying on the LCD key
and
Disable the AC led indicator on the keypad
Please advise how I can achieve this
Posted: Monday Feb 16th, 2015 10:45 am |
Posts: | 5498 |
in Alarm Types > Nondetector alarms, set the Power Failure Alarm type to Null to disable power supply alarm
Attachment: nondetectorpowerfail.jpg (Downloaded 55 times)
Posted: Monday Feb 16th, 2015 01:39 pm |
Posts: | 562 |
Just as an added note. Connect a mains relay with NC or NO contacts to a spare input or RIO and create a Response to execute when the mains fail.
For me I would like the response to switch off my Pool pump when running on UPS. If using ComfortClient you could have it send a custom SMS as well.Last edited on Monday Feb 16th, 2015 01:42 pm by Ingo
Posted: Monday Feb 16th, 2015 01:43 pm |
Posted: Monday Apr 4th, 2016 04:35 am |
dcrera
I run Comfort from a UPS backup battery. This weekend the keypad reported a power failure on low battery. It was after hours and I could not get a replacement and the system slowly shutdown.
I since replaced the battery and the system won't power up ! Thinking it might be the UPS, I connected the battery directly to the system with no avail.
Any ideas on what might be causing this ?
Posted: Monday Apr 4th, 2016 05:41 am |
Posts: | 5498 |
There is a SW52 pushbutton switch near the heastsink
If a battery is connected without a AC power supply, the system will not power up until the switch is pressed. This is for the situation where a house is not completed but the battery can be connected. The system will not power up or drain the battery
When the AC is ready it can be turned and the system will start running.
One of the many ways that Comfort is designed for practical use
Posted: Monday Apr 4th, 2016 07:36 am |
dcrera
Wow that was easy. I am back on.
It is SW51 on my board
Posted: Monday Apr 4th, 2016 08:13 am |
dcrera
I installed a brand new gel battery. Tested by the supplier. The battery was on trickle charge since 2:00 pm yesterday.
The system reports Power Failure Controller on the keypad and Power Supply Ac Failure - Low battery on my IPhone app.
The Alarm Type PowerFailure is set to null response.
PS: Tried acknowledging the message by entering my code on the keypad and it causes the system to go into Ready To Arm Mode
Posted: Monday Apr 4th, 2016 09:50 am |
Posts: | 5498 |
Go to Security Types> Nomdetector alarms> 3 Power Failure and set Alarm Type to Null or 0
Posted: Monday Apr 4th, 2016 09:54 am |
dcrera
If you referring to this, it has been done
Attached Image (viewed 23 times):
Posted: Monday Apr 4th, 2016 09:56 am |
dcrera
For confirmation, you can refer to my .cclx file I sent you
Thanks again
Posted: Monday Apr 4th, 2016 10:40 am |
Posts: | 5498 |
Measure the battery voltage at the battery connector when powering Comfort
If it is less than 11.5 V there will be low battery alarm
Posted: Monday Apr 4th, 2016 06:43 pm |
dcrera
Old Battery voltage 13.02
New Battery voltage 13.38
New Battery on Comfort battery terminals 13.22
New Battery on UPS output 13.34
Seems like there is nothing wrong with my old battery
Posted: Wednesday Apr 6th, 2016 03:08 pm |
Posts: | 5498 |
I think there may be something wrong with your settings that we cannot see from here
If non detector alarms for Power and Low battery are set to 0 then it is not possible for these alarms to be reported at all
Can you try writing to comfort again
when do you get these alarms after writing?
Can you send the Event log as well
Posted: Wednesday Apr 6th, 2016 03:27 pm |
