Posted: Thursday Oct 9th, 2014 08:27 pm |
dellboy13
Posts: | 12 |
Hi, I'm new to Comfort, I'm a broadcast computer engineer by trade, so setting up this type of technology is second nature plus I have installed a number of Galaxy systems etc.
I am thinking of buying a Comfort II ULTRA Control Panel in EN03 enclosure and adding LEM03-M2, UCM/CBUS, UCM/ETH3, DMO2 and RGR05. I know that some of these can be mounted on nylon risers above the Ultra board but I can not find anywhere a spec on what I can mount and where. Is it possible to put all my additions into the EN03 enclosures, or do I need to add more enclosures?
Cheers
Posted: Friday Oct 10th, 2014 06:47 am |
tech07
Posts: | 106 |
The UCMs, DM02 and LEM have same size, 108 x 88 mm with 4 x 3 mm mounting holes in each corner 5 mm away from each side
RGR05 is mountued on top.
LEM01 can also be mounted over the CM9000 board but it obstructs buttons led etc so it is recommended to mount on the base
You probably need another enclosure EN03 or the smaller EN01 310 x 350 x 95 mm
