Posted: Monday May 16th, 2011 04:36 am |
nizam.vd
Posts: | 9 |
Hello there,
I still new with comfort. My question may very common with you guy. The problem i have is how to read message that being record and how to record reminder message. When i want to set reminder, i completed the date, time and day the reminder but when to record the reminder message, it still said no message even though i have record my reminder when the Mic light turn red.
Another thing is when i go to record message (that i think for reminder message) it being save but sadly i dont know how to read or delete that message. Please help me since i really new with this comfort system.
Regards,
Nizam
Posted: Monday May 16th, 2011 05:02 am |
Posts: | 5493 |
Are you using the keypad?
Menu is 2 for mesages 5 for Reminder
Enter reminder number and # key
4 for messages
1 to record reminder message, 2 to hear reminder, 3 to erase reminder
"leave your message after the tone"
Then record your message when the MIC led is red and press and key to end
To hear and erase the reminder message, see the bold line above
If you have recorded it and cannot hear the recorded message check your keypad connections
Press F4 on the keypad to leave a message. Press any key to end. The MSG led should turn on. enter your code to hear the message. If there is no message recorded then there is a problem with your keypad connections
Posted: Monday May 16th, 2011 06:16 am |
nizam.vd
Posts: | 9 |
Thank you slychiu,
The instruction that you give to me help me a lot. That solve my problem...but if you dont mind, i got another problem. How to change the sound when door station being press?The sound seem to annoying and can i change the sound?
Regards,
Nizam
Posted: Monday May 16th, 2011 06:23 am |
Posts: | 5493 |
The default sound is a standard two tone doorbell chime. If yours is not, open the default template and write to Comfort
