Posted: Sunday May 15th, 2011 07:50 pm |
Could you explain the difference between the EN01 and EN03 expansion cabinets.
Maybe we could have some close-up pictures of them open etc as the pictures on the main Cytech site are small and dont really give much detail on how they open, their mountings etc etc.
Posted: Monday May 16th, 2011 07:45 am |
Posts: | 5493 |
some views on EN03 here. This is the usual enclosure supplied in the UK
Dimensions 358 x 375 x 95 mm
Removable Lid
2 tamper swithes for top and bottom
Base
Back View
Base another picture
Posted: Monday May 16th, 2011 07:52 am |
Posts: | 5493 |
EN01 is a smaller enclosure
310 x 350 x 95 mm
Posted: Thursday May 3rd, 2012 07:58 pm |
Am I counting the studs correctly to suggest I could mount 3x UCM's plus the main Comfort PCB inside an EN03 case?
J
Posted: Friday May 4th, 2012 02:16 am |
Posts: | 1200 |
UCM size modules can be mounted. eg LEM, RIO, DM02
For half size modules like ADM01, RLY01, RLY02 two of these camn be mounted on the ACC-PLATE2
Posted: Saturday May 5th, 2012 10:17 am |
Hi Admin
Not sure you answered my question though; how many ucm sized modules could I mount in the EN03 enclosure.
If I wanted an EN03 just holding UCM's (no main Comfort PCB) then how many could I fit (including those via the adapter plates you were mentioning)?
Basically my main comfort panel (one that came with my very originally sourced Comfort II kit from Home Controls as was!) is not an EN03 from what I can see but presumably something they had locally made fro the UK market at the time. I have my main Comfort II, power, battery etc in there plus 2 x UMS (Eth02 and Zwave). I want to add GSM and maybe another 1 or 2 UCMS.
If the "proper" EN03 holds 3 UCMS then I could replace my existing "Home Controls" sources case with one of these. Or I could mount a new EN03 next to it and put additional UCMs (but how many) in that. Or, because I like things to be neat and pretty put 2 new "pretty" EN03's next to each other and re-model my layout.
So understanding what I can fit in which chassis is order of the day.
J
Hi Admin
Basically my main comfort panel (one that came with my very originally sourced Comfort II kit from Home Controls as was!) is not an EN03 from what I can see but presumably something they had locally made for the UK market at the time. I have my main Comfort II, power, battery etc in there plus 2 x UMS (Eth02 and Zwave). I want to add GSM and maybe another 1 or 2 UCMS.
If the "proper" EN03 holds 3 UCMS then I could replace my existing "Home Controls" sourced case with one of these. Or I could mount a new EN03 next to it and put additional UCMs (but how many) in that. Or, because I like things to be neat and pretty put 2 new "pretty" EN03's next to each other and re-model my layout.
JLast edited on Saturday May 5th, 2012 10:18 am by juwi_uk
Posted: Saturday May 5th, 2012 10:25 am |
Posted: Sunday May 6th, 2012 07:44 am |
bs85
Posts: | 90 |
I have 3 UCM's and a main board in a EN03 and could add more. Attachment: IMG_0553.jpg (Downloaded 178 times) Last edited on Tuesday May 8th, 2012 08:29 pm by bs85
Posted: Tuesday May 8th, 2012 07:56 pm |
idheath
Posts: | 87 |
I think I may have a non-standard enclosure too (I originally had a Comfort I, purchased in the UK which I subsequently upgraded to a Comfort II which is now in the original enclosure).
I have the main Comfort II board, LEM03, ADM01 and a home-brew relay board in said enclosure.
I also have a UCM05 for programming (external to the box).
I plan to add 3 more UCMs at some point (Universal, GSM & Zwave).
My preference is to fit everything in one enclosure but I guess that's not going to work
I don't quite follow the detail of this thread i.e. what is the maximum qty of UCM's in an EN03 without a main board and what's the quantity with one?Attachment: DSCN4292.JPG (Downloaded 179 times)
Posted: Sunday May 13th, 2012 09:27 pm |
idheath
Posts: | 87 |
So what's the story with a EN03 enclosure?
I have a LEM03 & ADM01 and will have 4 UCMs so will all that fit in an EN03?
I didn't realise you can stack UCMs until I saw that in one of the photos in this post.
Posted: Monday May 14th, 2012 11:41 am |
The photos in this topic will show how many holes are on the EN03 for mounting
There are 3 positions for UCM/RIO sizes
If you stack UCMs you may be able to fit everything in but it will be rather crowded
It is best to get another enclosure
Posted: Sunday Jun 3rd, 2012 02:08 pm |
wexfordman
Posts: | 546 |
When using an enclosure fir expansion, what is the best mehtod for doing this with regards power supply etc. The reason I ask is I have both a spare comfort 1 and comfort 2 unit, and was thinking of re-using one or the other as an expansion enclosure and power supply! So, what would be the best method of doing this
1) Use comfort 1 enclosure and board with psu and battery
2) Use comfort 2 enclosure and the psu part of the comfort 2 board with psu and battery.
If I go for option 2 above, where do I take my 12v supply from seeing as it is normally given on the other half of the board, where can I take it where I know the 12v is combined from both battery and psu in case of mains failure ?
Thanks,
EamonLast edited on Sunday Jun 3rd, 2012 06:49 pm by wexfordman
Posted: Monday Jun 4th, 2012 02:10 am |
The Comfort 2 PSU board alone is not able to work by itself, because it needs the controller part to turn it on
Posted: Thursday Feb 7th, 2013 08:43 am |
Personally I think there is a need for either an adapter plate or revised chassis that allows for more than 3 UCM's inside the enclosure.
Yes potentially they are stackable but looking at a lot of mine they also have daughtercards with high components which IMHO would make it difficult to all fit.
If one of the upsells for Comfort is people adding more functionality through additional UCM's then IMHO Cytech should make it easier for people to do this. Maybe some thought to on how components are laid out on boards if UCM's are to be designed for stacking. For example I don't think I could stack the following combinations in the case (and boy I've toyed with it!).
* UCM/ETh02 and UCM/ZWave
* UCM/Eth02 and UCM/GSM
* UCM/ZWave and UCM/GSM
The daughtercards and high standing components blow this out of the water!.
Posted: Thursday Feb 7th, 2013 11:14 am |
Posts: | 5493 |
It is not feasible to fit all the modules you can possibly need into a single enclosure. The larger the size, the more costly it is to ship pverseas, and the current size is already contributing significantly to the cost of a Comfort in say the UK
Furthermore the large size of the enclosure makes it easier to be distorted during transport
The better solution is to use spare enclosures that are smaller and have the required mounting holes. Thus you only use the number of smaller enclsoyres that you need
Posted: Thursday Feb 7th, 2013 11:26 am |
17th Post |
Chiu,
That makes 100% sense and I'm all for keeping the costs down.
But even in en EN03 you can only fit 3 UCM side-by-side at the moment (correct?) with these I assume being powered from the main cabinet power supply/bus.
Surely we can physically fit more in this cabinet without even stacking if there were more mounting studs?
Can we have an adapter plate then instead (but that then adds to the weight) or maybe even more mounting screw holes.
An ideal scenario would be some sort of mesh (lots of threaded holes) that you could attach boards anywhere a bit like plugging some Lego onto its base board or a pcb prototype board.
Hey I'm thinking of Cytech revenue here; it's a lot easier to sell another UCM if you've got somewhere quick to install it without having to worry about buying a new cabinet, trying to find space on the wall to fit it, powering it, running cable trucking to it etc etc!
Posted: Monday Feb 11th, 2013 02:48 pm |
18th Post |
Posts: | 771 |
A yes
Have been there and even tried to patent the idea some years ago.
There are similar enclosures in manufacture in plastic let me know if it is of interest.
The example shown here is totally flexible - ill post some other picsAttachment: Borg boxes 012.jpg (Downloaded 104 times)
Posted: Monday Feb 11th, 2013 02:50 pm |
19th Post |
Posted: Monday Feb 11th, 2013 02:51 pm |
20th Post |
Current time is 01:12 am | Page: 1 2 |
