Posted: Monday Nov 29th, 2010 09:16 am |
EziAV
Can you please describe the start-up process Comfort goes through after:
1, System power cycle (removal of AC & Battery power)
2, Reset button pushed on the main board
3, Comfigurator Download
Is the Start-up Response ran in all of the above situations?
Are any other Responses or process ran?
I am trying to figure out why a driveway gate opens after a Comfigurator Download.
Posted: Monday Nov 29th, 2010 10:18 am |
Comfigurator full download will cause a Reset
Power On also causes a reset
The Startup Response runs whenever the system is reset
The gate opening may or may not be due to the Startup Response. You may have open zones causing a Zone Response, for example
To find out all the events which trigger the Response, do a Right Click on the Response and click "Show References"
