All in one keypad ?
 Posted: Monday Feb 15th, 2010 11:23 am
palmlodge
I'd like to start to collapse my wall controllers. To start with, the entrance which has a KP04 and a CBUS DLT.
So, what options do I have to replace a KP04 and a CBUS switch, into one unit, that allows signin with Comfort and the comfort audio feedback (I already have a UCM with audio board to go)
TIA
 Posted: Tuesday Feb 16th, 2010 05:56 am
Wizcomfort 2 currently beta 1.9.0 see http://www.comfortforums.com/view_topic.php?id=1662&forum_id=21 running on a wallmounted Windows touchscreen would do the job
It connects to UCM/audio module either on Rs232, USB or Ethernet
Currently we do not supply am embedded PC touchscreen but there should be many third party products available which run Windows XP or embedded
 Posted: Tuesday Feb 16th, 2010 06:09 am
palmlodge
I wasn't thinking of a PC touchscreen but an off the shelf Cyech or Clipsal product. What are the options ?
 Posted: Tuesday Feb 16th, 2010 07:26 am
In that case, the new KT03 monochrome touchscreen keypad to be launched in the 2nd half of this year should be exactly what you need. It can be mounted in Horizontal orientation
Or Vertical
It has built-in speaker and microphone
Ignore the old icons, It will come with new refreshing icons, or you can use your own images. Completely programmable using Comfigurator
This is a sneak peek
 Posted: Tuesday Feb 16th, 2010 08:04 am
palmlodge
What capabilities does it have for being able to slightly customise so i can control CBUS (via the CBUS UCM) ?
 Posted: Wednesday Feb 17th, 2010 01:40 am
This will allow you to put in buttons that can send any command to Cbus and to display the state of C-Bus group addresses (with the UCM/C-Bus)
 Posted: Wednesday Feb 17th, 2010 05:14 am
palmlodge
Great. And what are the dimensions ?
 Posted: Sunday Nov 7th, 2010 07:20 pm
I gather the KT03 is programmed via Comfigurator.
Can the configuration be uploaded to the KT03 via UCM/Ethernet?
 Posted: Monday Nov 8th, 2010 12:07 am
The KT03 configuration is written to the KT03 through a direct USB connector on the KT03.  It cannot be done by Ethernet
The KT03 USB connection can also be used to write the Comfort configuration to Comfort, so it acts like a UCM
 Posted: Monday Nov 8th, 2010 05:03 am
So the USB interface is on the KT03 itself.
Is there a hidden flap that opens then or does it have to be removed from the wall etc to programme.
Just trying to understand the steps involved.
It's a shame you can't program through UCM/Eth as it would seem I'd need to balance a laptop on my knee to program a keypad half way up the wall next to my back door and hope nobody wants to enter/leave the house whilst programming it?
 Posted: Monday Nov 8th, 2010 05:12 am
The Front Bezel can be removed, and the USB can be accessed.
It was decided that a direct USB connection  is the simplest way as an Ethernet connection requires another cable to be run to the KT03 besides the Comfort bus
 Posted: Monday Nov 8th, 2010 05:18 am
Please post further comments on the new KT03 forum, see http://www.comfortforums.com/forum90/
 Current time is 07:25 am
