Posted: Thursday Jun 5th, 2008 04:45 pm |
pete_s_h
Posts: | 12 |
Is it possible to disable a tamper alarm caused by removing the Comfort enclosure box from the keypad?. I recently had to alter the telephone copnnection and this resulted in a tamper alarm which could only be reset by pressing the green button inside the enclosure. In order to replace the cover I have had to mechanically disable the tamper switch. How should I reset the alarm after replacing the cover?
Posted: Friday Jun 6th, 2008 02:31 am |
You can go to Test Mode which is F3,2 which will temporarily disable the alarms while you are working on it
Posted: Saturday Jun 7th, 2008 12:49 am |
pete_s_h
Posts: | 12 |
Thanks for thie information. I am currently away from home for a couple of weeks and will try this when I get home.
Posted: Monday Jun 23rd, 2008 01:58 pm |
pete_s_h
Posts: | 12 |
Thanks slychiu
I have tried doing this and re-setting the tamper alarm by pressing the re-set switch on the main board but I still get another tamper alarm when I put the case back on. I need to be able to re-set this from the keypad.
Does anyone know how to do this?
Posted: Monday Jun 23rd, 2008 02:02 pm |
Posts: | 1200 |
I dont understand what the problem is
Press F3,2 on the keypad to go to security Check. This will disable all alarms while you are working on it
When you finish, and put back the cover on the case, the tamper should be closed.
Press F to exit security check. You should not have an alarm.
Can you describe exactly what is happening and what you have done
regards
Posted: Monday Jun 23rd, 2008 02:47 pm |
pete_s_h
Posts: | 12 |
Thanks admin
The problem was that my installer had located tamper switch so that the cover screw was not actuating it when the cover was on. I have now moved the switch so that the cover screw actuates it when the cover is replaced.
Thanks for the help.
Posted: Tuesday Oct 18th, 2022 11:04 am |
sppooky
Posts: | 11 |
Hi i changed the battery and reconnected the phone out connections within my alarm panel. I'm now getting a tamper alarm controller warning on my keypads. In hindsight i should have temporarily disabled the alarms as you mentioned above - but i read that too late!. Is there a way for me to acknowledge the alarm from the keypad and hence remove the warning?
Posted: Tuesday Oct 18th, 2022 11:27 am |
Just enter your code on the keypad and # key.
That will disarm silence the alarm
Posted: Tuesday Oct 18th, 2022 04:43 pm |
sppooky
Posts: | 11 |
I tried that. But the message 'tamper alarm controller' remains on the keypad. When i enter code i Get options 0 for security off, 1 to arm security, 3 for security options....but nothing within them is removing the tamper message.
Posted: Wednesday Oct 19th, 2022 02:15 am |
The keypad display of alarm will remain until the tamper is restored. Pleaser check the tamper terminals - they are open and thus
should be causing the alarm. The telephone line should not have any effect on the tamper.
You can also dfo a Security Check mF,3,2 on the kleypad to hear all the open zonmes including teh tamper
